Using Multi Meter
Old Aug 24, 2007 | 12:11 AM
waz57's Avatar
Default Using Multi Meter
Okay who out there can tell me whcih settign I need to have my multi MEter on to test my battery and also the charging system, I have never in my 50 years had to use one so am a litle confussed as I have no instructions. Now I have the Black wire ( Earth ) pluged into the 10ADC and the red Wire ( Power ) pluged into the VQmA socket now I have selected the V- 200 and it reads approx 12.7 have I done this right ???
Old Aug 24, 2007 | 12:19 AM
MarkR's Avatar
Default RE: Using Multi Meter
Sounds about right
I would set it 20v if you have the option, but 200v is ok
red to red, black to black
when you rev the bike, the volts should go up to around the 14-15
Old Aug 24, 2007 | 01:21 AM
R1000's Avatar
ORIGINAL: waz57
Maybe it is the way your specificmeter should be connected, but putting the black wire (earth/minus) to 10 ADC sounds odd to me. Normally one connects minus toa COM terminal.
http://www.doctronics.co.uk/meter.htm#digital
[IMG]local://upfiles/4562/EA0A3258CA924245BA059EB373BE63D9.gif[/IMG]
Old Aug 24, 2007 | 01:48 AM
waz57's Avatar
Thanks R1000 I have taken a pic of my Multi Meter just to make sure its right and aslo what setting do I place it on to check what is left in the battery thanks. Went to start my poor old 92 today as I havnt been ridign her in favour of the bird and she went urrr urrr urrr tick tick so I knew the battery was on its way and that proved it.
[IMG]local://upfiles/7739/B3AB9E6A16F2406F911364873AFA0857.jpg[/IMG]
Old Aug 24, 2007 | 02:14 AM
R1000's Avatar
When measuring voltage the black shall be in the middle terminal (COM). It worked in your case since the high amp shunt resistor is placed on the minus-side. Another model would haveburn or burn the fuse.
Since the instrument draw very little current, the voltage value will be the same when you connect it correctly.
The red wire is correct and the 20Vsetting is also correct, just move the black to COM.
Old Aug 24, 2007 | 05:31 PM
waz57's Avatar
Thanks for that Info R1000, I found my problem on my old girl I had blown a fuse up in the fuse box.
Old Aug 24, 2007 | 07:32 PM
waz57's Avatar
R1000 Just another quick question please, I placed the new battery in the old girl fired really easy and I placed the Voltmeter on the battery and got the following figures they seem right to me but I am always open to opinion. Wazza
1000 RPM - 12.68
1500 RPM - 13.98
2000 RPM - 14.98 to 15.01
Old Aug 25, 2007 | 12:55 AM
R1000's Avatar
The readings looks great, it charges realfine already a 1500 rpm. 15 volts is a bitinto the high side but since it is normal for the CBR 1000 F it is quite OK.
Edit: added pic from service manual
[IMG]local://upfiles/4562/87E2F8C1171047FB843A46AF379C51F2.jpg[/IMG]
Old Aug 25, 2007 | 01:14 AM
waz57's Avatar
Thanks for you help R1000. Have to try and ride my 92 a bit more but the bird is so new and nice !!!
Old Aug 25, 2007 | 02:07 AM
R1000's Avatar
Yes new is always new, I'm sure you are happy with the bird
