Temperature gauge?
Is it normal for the temp to go from high to low rather rapidly? It always comes down....but seems to go all the way hot at times. Just want to make sure that's normal. The fan will kick on when I'm stopped, and that brings the gauge down, too. Just getting used to a new bike and want to know what's normal.
Thanks,
Warner
Thanks,
Warner
I'm going to flush and replace the coolant......with Engine Ice. See if that helps. I've read these things can run hot, and the way it's fluctuating makes me think it may be a little low on coolant.....going to do that before I ride anymore.....after riding home from work today, anyway....
Warner
Warner
Normal....
There are many post here about that subject. General consensus is, (myself included) temp gauge goes up to 3/4 scale when stopped in traffic. The fan kicks on and holds at around 3/4 scale. Upon hitting the open road again, the needle drops back to 1/4 scale and holds steady. Normal...
At one time the 1kF was the fastest production bike before the CBR1100xx came out. I guess Honda wanted to shave weight and decided a smaller radiator was the trick.
If you have she open, replace the radiator cap and thermostat as well.
When I first got my CBR, it was still pretty cold outside, so I experienced no issues with over-heating. But the first time I rode it in hot weather, the Temp Gage shot up into the Red Zone. It freaked me out. I decided to examine the system, as well as drain and flush it. Good thing I did. I've never seen coolant look like that before. Very odd color, and strange viscosity. I drained it out completely, and removed the radiator to check it out thoroughly. I carefully blew out all the bugs and other crap lodged between the cooling fins. I cleaned it gently with soap, water and a soft bristle brush. Checked all the hoses. Reinstalled everything and flushed the system with water and vinegar. Put in fresh coolant (safe for aluminum) with Distilled Water. I took it for a long ride, and everything seemed fine...until I got stuck in some heavy traffic. It started over-heating again. I did hear the fan kick on, so I didn't think that was the problem. But I thought perhaps the fan switch was intermittent or defective. Some trouble-shooting indicated that the fan switch was acting oddly, so I ordered a new one. Put it in, took it for a ride, got stuck in traffic again, and it began over-heating again. I looked at everything again, and this time discovered that I had accidentally left off the fan ground wire which attaches to a mounting bolt near the top of the radiator. D'OH!!! Once I hooked that up, all was well. My gage rarely hits the halfway point. It's usually right around 3/8 of full travel. Only when it is extremely hot outside and sitting in stopped traffic does it ever get to the halfway mark.
So, flush coolant with water and vinegar, make sure radiator isn't blocked with crud, use distilled water with new coolant. As long as the rest of the system is working correctly, you should see much cooler temps.
Warner
I recently flushed mine, new radiator fluid, pressure washed carefully the radiator grill.
I have ordered a new radiator cap and thermostat.
While I wait for my used stator to come. About all I do till then is charge battery and ride for about 30 minutes.
A few more days.
I'm actually suspecting the heat ruined the stator in the first place. Because before the stator failed, the bike would get close to the red at stop signs in town.
After reading a few posts, I did the flush and new fluid.
Which only helped a little. I was still 3/4 over on the gauge. And normal was in the middle of the gauge after 1 hour of riding.
But now that I'm in limp mode until the stator comes. I hope to ensure the bike is running cooler.
Ryan
A few more days.
Ryan
