Alternative Parts What fits where, what else will fit, resources + bike manuals
radiator cap
Old Jul 7, 2010 | 04:18 PM
raiden's Avatar
Default radiator cap
i bought a radiator cap from auto parts and i wonder if this cap will works for radiator bike, its the same size 1.1 16lbs. and its cheaper than honda radiator cap.. any idea?
here's the parts number > Prestone RR33 and this cap belongs to NSX v6 cars..
Old Jul 7, 2010 | 09:44 PM
hawkwind's Avatar
Many alternative parts are identical for this bike, but a lot cheaper.
Shadow pointed this out for the temperature sender unit, and in fact started the 'alternative parts Sticky'.
Give it a try, if the specs are the same it should work fine, and you can add your own contribution to the above mentioned thread
Old Jul 7, 2010 | 11:36 PM
raiden's Avatar
the cap was exactly fit to radiator and my bike running without thermostat and nothing issue so far. .
Old Jul 7, 2010 | 11:59 PM
hawkwind's Avatar
If the Rad cap is the same fit and the same spec all seems good
If the spec's are the same, chances are it's the same part...just not the Honda price
Let us know how it goes and then you can be Immortalised in our 'Alternative Parts' sticky all we need is a part number or alternate model
Old Aug 16, 2010 | 09:42 PM
raiden's Avatar
the rad cap is safe to use now , it didn't blow up my bike and running a bike without thermostat is safe too , the needle temp. gauges won't go up to red line..
Old Jun 21, 2011 | 07:46 PM
900RRider's Avatar
Default Alternative automotive radiator cap
Thanks for the part number
Needed one for a 2000 Shadow VT750 and it fits
Only cost $8.50 at local auto parts store vs $30+ online prices
Old May 28, 2013 | 01:19 PM
TimBucTwo's Avatar
Noticed my 2005 Subaru Outback had the same cap so I went to the auto store and picked one up for $7.49 USD.
Its packaged by ToughOne part #10233, same as Stant #10233 that fits many radiators.
Old Jun 2, 2013 | 04:56 AM
Bordo's Avatar
I replaced mine with an after market one from a local auto parts store. Honda caps have a 10 to 15 psi valve in them for this particular bike. I checked the after market one with my mity vac kit and the valve activated at around the 15 psi mark so I knew it was good to go. Cap cost me around 10 dollars from memory. A Honda one here is around $30 I think.
weston123
Apr 30, 2013 06:30 PM
tpgpz
Jul 19, 2010 01:00 PM
Cytotek
Jun 16, 2010 11:10 PM
f3bika87
Oct 25, 2008 08:09 PM
