Starting problems.. universal parts?
Old Feb 20, 2007 | 01:46 PM
renxwar's Avatar
Default Starting problems.. universal parts?
I'm having trouble getting my bike going, I'm pretty sure its the ignition switch. When I turn it (most of the time) everything powers on, but it just "clicks". If I move the key on and off on and off eventually it starts and goes like normal. I was looking on ebay and found one ignition switch for 30$ but its in UK. I see quite a few CBR600F3 and CBR1000RR swiches on ebay for 9$~ and I was wondering how universal these switches are? If the plug isn't the same thats not too much of a problem, that can be wired up.. but if it doesn't mount the same way that could prove to be a problem. Thanks for the help.
Old Feb 20, 2007 | 06:23 PM
Motor_Fan's Avatar
Default RE: Starting problems.. universal parts?
Just an advice... Before you start spending money take a look at the batery cable terminals, check if they are tight, if cables are ok, and if they don't have any oxidation. You can also take a look at your fuse box to see if no conecting weires are loose, orpresence ofsome oxidation or rust. The problem you described some times is also related with these parst as well.
Goodluck
Old Feb 21, 2007 | 03:32 PM
renxwar's Avatar
Actually, I narrowed the problem down to not the actual key part, but the OFF / RUN switch. It seems I need to push it down alittle harder than normally now. Those I *KNOW* I can get elsewhere, if it does end up dying.
Old Feb 21, 2007 | 05:15 PM
Ghost1Rider's Avatar
If I touch my kill switch, I can be there for 10 minutes flicking it off and on before it starts. The switch is a common problem.
Old Feb 21, 2007 | 06:34 PM
Motor_Fan's Avatar
The switch was the only thing I forgot to tell in the last post. It starts giving head akes in short while. Its simple to fix thow.... Dismount the buntons, and the kill switch has one wire feed and one wire exit of the 12 volts for the coil. Simply just weld a wire between the 2 terminal of the switch and you'll never have any more problems. Also you can olny turn the engine off from the ignition switch.
Old Feb 21, 2007 | 11:05 PM
yas001's Avatar
renxwar,
Check out Dennis Kirk @ www.denniskirk.com. Their part number is 20-0270. 48.99 usd.
95&97_cbr_f3
Jan 23, 2010 08:19 PM
jokerschild275
Jul 8, 2008 09:29 PM
fallen771
Oct 21, 2007 04:04 AM
grwilson6
May 8, 2005 02:53 AM
