starter motor, clutch or worse?
Old 02-27-2008, 04:43 PM
GARMIN1000F's Avatar
Default starter motor, clutch or worse?
so looks like some dimwhit had tried to start the bike with the wrong battery and fried the starter solenoid. Does anyone have one that is known to work? If so please let me know
also in need of a clutch lever if available.
Old 02-27-2008, 07:50 PM
Default RE: in need of a starter solenoid and clutch lever
For clarification, when you're referring to the "Starter Solinoid", do you mean the "Starter Relay" ?
Old 02-27-2008, 10:15 PM
Shadow's Avatar
I have a complete starter motor for an 87/88 model. Let me know if you need it. Have you done the basic tests in Sect 16 of the manual ? It may be something else, like a sidestand or clutch switch........
Old 02-28-2008, 05:21 AM
Trips's Avatar
Do a search on Ebay etc. You can use any generic 4 pin fused Solenoid as long as its rated to 30A. SHould be able to pickup one from a Auto Sparky for $30 or so.
Old 02-28-2008, 07:53 AM
GILL's Avatar
how would you "fry" your starter relay with the incorrect battery? Wouldnt it have to be a higher voltage than a standard 12V battery? Perhaps boosting it from a car maybe....but 12 volts is 12 volts. In any case the 30A fuse should have popped before the relay, check that first.
clutch levers are 10.00 from the Honda Dealer here and they come all shiny and new!
Old 02-28-2008, 09:41 AM
hmmm. the starter motor turns over when connected to the battery but not through the relay. what else could it possibly be? it could be any relay rated 30 amps?
Old 03-01-2008, 09:10 PM
Trips's Avatar
Check all the wiring to the Solenoid as it sees to burn out over time meaning the same current has a smaller contact area to flow though causing even more burnout.
Old 03-02-2008, 07:39 PM
cdrewferd's Avatar
I am parting out my 91, let me know if you need any parts. I have everything but the front calipers, clutch and swingarm avaliable.
Old 03-04-2008, 07:48 AM
ok so i replaced the starter relay and now the starter will turn over but the motor will not..... so i guess im going to have to pull the motor, alt. and starter clutch tonight. I have seen one post here about doing this with the motor in the frame so I am going to give it a try and have my girl take lots of pics while i tear it all apart
Old 03-04-2008, 09:06 AM
Shadow's Avatar
Do you mean it won't turn over, ie siezed, or won't fire, ie start ??
Before you go to those extremes, do all the checks in the manual.......may
save you a load of trouble.......
Quick Reply: starter motor, clutch or worse?
