Standard light functions
Old Jan 29, 2024 | 09:08 PM
konatodd's Avatar
Default Standard light functions
Hey there, I finally got a new battery and powered up my 88 1000F, all signals work, brake light works, taillights work, hi beam works.
Low beam not working.The one thing I am wondering is with key power on my front 2 signal lights are powered, then when you put on the turn signal the flash brighter, the rear signal lights are off until I use the turn signal switch……. Is this normal?
thanks in advance,
Todd
Old Jan 29, 2024 | 11:46 PM
dannoxyz's Avatar
Remove headlight bulb:
1. Verify that low-beam filament is good or bad. Easy test is to power bulb directly from battery with jumpers.
2. Key ON, verify you have battery voltage at low-beam terminal in bulb socket
Yes, rear winkers only blink when signal switch is flipped to L or R
Front lights have dual-filament bulbs for 2 functions. One is marker lights that’s ON whenever key ON. When signal switch is flipped L or R, marker lights turn OFF and winkers blink. Should be completely OFF during blank interval of winkers.
Old Jan 30, 2024 | 06:30 AM
konatodd's Avatar
Awesome thanks! I’ll check it out further on my next days off.
Todd
Old Feb 8, 2024 | 08:45 PM
konatodd's Avatar
Thanks dannoxyz,
I got all the lights working correctly now, front light was a burnt low beam and I had one right rear taillight out.
Todd
Old Feb 8, 2024 | 11:36 PM
dannoxyz's Avatar
You’re welcome! Yay!! Awesome work!!!
LightningAge
Aug 22, 2021 12:20 AM
patsf1
Jun 18, 2021 08:19 AM
600cbr18
Mar 2, 2011 12:04 PM
catchx34
Sep 24, 2008 10:03 PM
TommyJ
May 6, 2008 11:22 PM
