Slippery when wet
Old Sep 4, 2006 | 05:15 PM
rhino94's Avatar
Default RE: Slippery when wet
The ST-020 tire I can not find anywhere?
Old Sep 4, 2006 | 05:37 PM
Steve_Cardiff's Avatar
Hi Rhino,
What type of Battleaxe tyre are you using?
I have the BT020 on mine and I think they're superb in the dry and great in the wet. Living in the u.k and riding all year round i see my fair share of rain and haven't had any problems with them.
I can spin the back wheel but it really needs provoking.
You also say you have 5900 miles on the back tyre with 2 mill tread left?? That tells me they're probably not the 020's.
If you want to go 10K + miles between new tires, then they are what you want. If you want to be able to corner and ride in the wet, go for something else.
Are you kidding? I only ever get about 4500 out of a rear and about double out of the front.
Old Sep 4, 2006 | 06:28 PM
rhino94's Avatar
Hello
I have BT020 and I measured today I have 4mm left in the middle.
The spinning don´t need much provoking.
In wet conditions:
3/4 throttle 2nd gear 7000rpm it spins.
In corners after a crossing I can hardly touch the throttle in 1:st gear before the rear comes out
Terrible
Must be something wrong. I will change to Metzler this week.
I will go on track in Falkenberg, Sweden friday the 15:th this month so I have to be prepared :-)
Edit:spelling
Old Sep 4, 2006 | 06:55 PM
I reckon you must have a serious contamination issue. Maybe something to do with the de-greaser you're using.
You've got 4mm left after how many miles???
Don't change to Metz. Believe me, the Bridgy is a better wet weather tyre. If you're gonna change, i'd go for the Avon Av45/46 st tyres.
Old Sep 4, 2006 | 07:13 PM
rhino94's Avatar
As earlier stated 5900 miles, (9500 kms if I calculated correctly)
The Metzler is already ordered so its too late.
It could be one other thing, that the chain oil splashes the tire.
Old Sep 4, 2006 | 07:14 PM
BackTalk's Avatar
Please DO NOT take this wrong cause I have done it. Is the tire mounted in the right direction?
Old Sep 4, 2006 | 07:18 PM
rhino94's Avatar
Yes it is, I checked again to be sure.
I didn´t mount the tire, a local firm did.
Old Sep 4, 2006 | 08:06 PM
MarkR's Avatar
Could there be a difference in tire performance between the older bikes with the thin tyre and the newer bikes with the wide?
Old Sep 5, 2006 | 12:16 AM
Illushun's Avatar
I am on my second set of BT014 hp's. I am taking wet turns 2/3 speed of dry. I got the front to last 5k miles, and only 3k miles on the back. IMO they grip very well, but have a short life. I'll stay comfortable with a shorter life for my confidence in the tire. I wouldn't call myself a basic rider, maybe an intermediate if the 3 levels were novice, intermediate, expert. They do well. adjust tire pressure by 1 or two pounds and I notice the difference on cold or warm tires.
I am planning to not be so brand specific and start to consider alternatives next change around.
Old Sep 5, 2006 | 01:59 AM
There could be a massive clue here!!!
