Single Seat Cowl for 1000F
Old Mar 21, 2009 | 07:33 AM
cbrsixpack's Avatar
November 2009 ROTM
Default Single Seat Cowl for 1000F
Impossible to find!!
Wreckers,Ebay,Honda Australia,etc etc.
So,with a little common sense[lol] have a go yourself,make your own..........
Utmost important,think ahead.............!
1.Do a prototype fitment using card board,design,the shape to suit.
2.I went one further,too less than 1 mm sheet metal,great fit but couldnt get the curve correct at the very end.
Pics...
Went to a fibreglass shop,bought what i wanted,for $35.
Too start off your process,Masking tape the whole seat that isn't part of the process.
Too make your cowl ,Glad wrap[cling film] your section at least 3 times,Mask underneath the seat also.
Use the Dummy[s] to cut your profile from the matting.
Lay Matting straight on the seat,start pasting with your chemical kit.
1st layer is easy,let cure overnight[was 90+ degrees here],lay the 2 nd layer ,pasting the previous layer,then go for it!
Pics...........
Let cure overnight,lot off excess to trim off,but learn how you go.
Mine pulled clear of the seat,no damage via chemicals whatso-ever.
Problems i found.......!
1.Air bubbles from the 2nd layer.
2.Body Filler/Spray putty will play a huge part in this proto-type..........lol
As it was yesterday.....
Pic.....
* As of today,ready for Painting.
*I do not take responsibility for others acting on this information,with their own property.
*Gell pack ,Master Mould is already ordered,to mass produce for 1000F customers.
Old Mar 21, 2009 | 09:07 AM
Shadow's Avatar
I'll be having a go, Rob
Nice one !
Old Mar 21, 2009 | 09:47 AM
DragonCBR's Avatar
Hi all i got the look of the seat cowl without it see my pictures, solution : two tones seat
Attached Thumbnails Single Seat Cowl for 1000F-user13094_pic7612_1225148656.jpg
Old Mar 21, 2009 | 06:08 PM
Trips's Avatar
How do you plan on fastening the cowl to the bike?
Old Mar 21, 2009 | 07:11 PM
cbrsixpack's Avatar
November 2009 ROTM
Will post up a pic when i have done it,later today,all going well.
Old Mar 21, 2009 | 11:47 PM
Shadow's Avatar
It might be a plan to "wrap" the bottom of the mould slightly under the seat to allow it to grip.......There should be enough flex if it's only two layers of glass.
I thought your metal effort was outstanding too - could you not have sorted the profile with an english wheel ? Seems like a lot of effort and sooooo close !
BTW Rob the pics don't work in your last
Old Mar 22, 2009 | 03:37 PM
Red Baron's Avatar
Talking
Why don't you get one of these???
* sorry I just noted is not the same year.
Old Mar 22, 2009 | 03:54 PM
sawnee's Avatar
If you wanted a bit more shape you could layer sponge or paper mache onto the seat before glassing over it, just a thought
pepperman
Dec 8, 2011 01:49 AM
vangill
F4i - Wanted
Aug 8, 2010 10:40 PM
Quick Silver
Aug 25, 2009 08:42 PM
cbrsixpack
Nov 28, 2008 01:40 PM
