Scratching my head....
Old 08-11-2008, 08:59 PM
fast1000f's Avatar
Default Scratching my head....
Anyone have any explanation why I would be able to pull the #4 plug wire and my bike still runs with no sound difference. If I pull the #1 the bike dies.....i can put a plug directly in the #4 wire and it sparks like a big dog....
Old 08-11-2008, 09:07 PM
MarkR's Avatar
Default RE: Scratching my head....
Are you say the coil lead to the plug (big black thing) or the coil wire (small coloured thing) from the bike to the coils
Old 08-11-2008, 09:14 PM
fast1000f's Avatar
I have tested both 133.0v and 11.4v respectively.
Its when I pull the plug wire from the #4 spark plug that it still runs. If I pull the #1 spark plug wire, it dies.
Old 08-11-2008, 09:21 PM
MarkR's Avatar
If you pull the #4 Plug Lead and it makes no different, then #4 cylinder isn't firing - you have a problem.
If you pull the small black power cable from the bike to the coil-1 only, then it wont make a diffrents until you pull the small black wire on Coil-2
Old 08-11-2008, 09:27 PM
fast1000f's Avatar
THen I have a problem....think the #4 Cyclinder isnt firing...next step compression test?
Old 08-11-2008, 09:57 PM
MarkR's Avatar
Check for spark, I believe that #4 & #1?? (both leads from the same coil) fires at the same time, so you can switch coil leads to test the cylinder - not 100% on this one, but mostly sure
(Plug ussally fires twice, one on stoke, once 180 degress off)
Old 08-11-2008, 09:59 PM
MarkR's Avatar
could be a carbie
Old 08-12-2008, 07:49 AM
fast1000f's Avatar
cleaned all the carbs already, jets, floats, bowls, slides. but i will try swapping the #1 and #4 wires to test cylinders. thanks ill get back to you
Old 08-12-2008, 11:00 AM
TimBucTwo's Avatar
I would check compression also.
Old 08-12-2008, 11:24 AM
Harry_T_Hamster's Avatar
I'll say it AGAIN lol - this is EXACTLY the prob I was having when my CDI went
Quick Reply: Scratching my head....
