Replacing Linked Brake hoses with S/s
Old 08-23-2010, 04:14 PM
Dean0's Avatar
Originally Posted by skatrekker
Thanks Deano, I'll let you know how it goes ... may be even a photo illustrated how to depending on my enthusiasm.
I owe you a pint or two
If your good with a drill and handy with the spaners - these pics show how to link the pistons from INSIDE the caliper - it looks real neat with just a plug outside the caliper instead of a link hose.
Attached Thumbnails Replacing Linked Brake hoses with S/s-cbs-caliper-inside-1.jpg   Replacing Linked Brake hoses with S/s-cbs-caliper-inside-2.jpg
Old 08-29-2010, 09:43 AM
skatrekker's Avatar
Question Cb1300 front m/cyl
Any other m/cylinders that would be as good, as I can't seem to find any for sale anywhere (2 nd hand obviously ) ?
Old 08-29-2010, 10:54 AM
TimBucTwo's Avatar
I also drilled the rear. It takes a little time to get use to the better breaking back there. I would suggest you drill but go with a rubber hose to soften the feel. I built my brackets for some aluminum flat stock from the hardware store. Then at the same store I picked up some large washers and a pack of cable ferrules to build spacers from. Keep some the original hose holders and reposition them to hold the new SS lines.
Attached Thumbnails Replacing Linked Brake hoses with S/s-bracket.jpg   Replacing Linked Brake hoses with S/s-spacer.jpg   Replacing Linked Brake hoses with S/s-washer.jpg
Old 08-30-2010, 08:11 AM
Dean0's Avatar
Your looking for a 14mm bore master cylinder - The reason for the CB1300 one is that it matches the clutch reservoir perfectly.
sjwagstaff
11-14-2011 09:27 AM
ezwryder
11-09-2009 10:18 AM
Black Rider
11-01-2009 06:09 PM
racerrick
12-04-2007 01:12 AM
Quick Reply: Replacing Linked Brake hoses with S/s
