Rear Wheel.
Old Mar 17, 2013 | 05:01 AM
weeto1964's Avatar
Default Rear Wheel.
Hi, need some info re. rear wheel spacers, when I bought my bike an '87 CBR1000f it already had the rear mod, as in it had a 89 on rim.
problem I have is it didnt have the correct spacer on the disc side of the wheel, it had a spacer and a couple of washers to make it up to the correct size, now since i have had the rear off, I can't remember how it went together.
could some one please let me know what size spacer should be on that side, i have a part number but it doesnt give the dimensions of it.
I have got the wheel back in, but misplaced the washers, what i have done, is use the original spacer from the original front wheel (wider than orig rear) plus a washer, but not sure if its all lined up properly.
not even sure its assembled properly, should the calliper brace be directly against the swing arm then a spacer? if you know what I mean! as i have it now the cailliper seems to line up with the disc
Old Mar 17, 2013 | 06:10 AM
DragonCBR's Avatar
The set up I had on mine with the orginal 87-88 spacer in the back was the 5 washer( 1mm each) on the right side of the rear wheel ( brake disk side). If you want to get a spacer cut to the right size get a 89-93 spacer and cut it to the 87-88 orginal size plus 5 milimiters.
Old Mar 17, 2013 | 06:59 AM
weeto1964's Avatar
Hi thanks for the reply, but the only problem is, I dont have any of the original bits that came off the rear, it had already been done before I bought it.
I just dont know how thick the spacer should be, I am just asuming the spacer on the sprocket side is correct, but knowing how thick that should be would help just to be sure.
Only other option would be to buy 2 new spacers, just to be sure.
Also am I correct to assume there is no difference between the '88 and '90 swing arm?
Old Mar 17, 2013 | 08:24 AM
Sprock's Avatar
Weeto mate - I'll go out and check that for ya shortly - before I get going on "Green Day" festivities
Gimme an hour or 2 and I'll snap a pic of the spacer setups on both scenarios
Old Mar 17, 2013 | 09:41 AM
weeto1964's Avatar
Thanks for that, I am pretty sure I have done the front end conversion ok, I cheated, I bought 2 new spacers for it approx £14, but the rear is a mismatch I think with spacers and washers, I think I would prefer to buy new ones so the job is right.
Will take a snap of mine I'm the morning so I can compare as bike is in a shed at work at the moment.
Will also post a pic up of the bike with the matching newly powder coated rims on.
Thanks again. Alan.
Old Mar 17, 2013 | 09:50 AM
weeto1964's Avatar
Got the speedo working off the sprocket cover drive now, not much left to do for this season now, oil change and plugs and a few other bits and pieces.
Old Mar 17, 2013 | 05:20 PM
Sprock's Avatar
confirming distance between arms same for both
Old Mar 17, 2013 | 05:47 PM
HenryM's Avatar
How lucky we are to have a polygamist in our midst.
Old Mar 18, 2013 | 07:19 PM
Sprock's Avatar
Well then Henry maybe I should restate that to
"distance between the legs is the same"
Old Mar 20, 2013 | 09:03 AM
weeto1964's Avatar
Thanks Sprock, would be good if I knew the distance so I can try to get it something like, cheers Alan.
