Rattle snake in my CBR1kF + some questions + pics
#21
on
Yeah well Sergio it's a recurring problem in all gens of Hurricane even tho' the later
tensioner design was a "bit" better - I see a CCT job in your future - go for it man plenty
of us here to help you with it from across the miles even of we are all sitting back sippin'
beers as armchair mechanics and spectators
#22
I modified buthead1000's:
https://cbrforum.com/forum/newreply....eply&p=1205337 (Clickable - obviously)
to this: (also in How To in shorter form as "CamAdjuster Completed":
https://cbrforum.com/forum/hurricane...tthead-125029/ (Clickable - not obviously)
but had HenryM done his first I would have used this:
https://cbrforum.com/forum/cbr-1000f...0f-cct-139116/ (Also clickable - not obviously)
#23
I still don't get it comrades...
If you buy a new, original Honda CCT and the noise come back after few thousand km, what is the worst case scenario? I mean, it makes no sense if you have to redesign and tweak something that Honda engineers designed and constructed, right?
I can't accept that Honda created something that will last only a few thousand km and can cause problems in the motorcycle with 1000cm3 and over 130hp. What was the case back in the 'early days' while these bikes were new? I doubt someone was tweaking the CCT on the brand new bike?
I see many of you don't pay much attention on rattling and oscillating noises, you just ride the bloody thing instead The questions is: where is the limit? How do you know when it's critical and it's time to do something about that?
Sergio
P. S. Yes, yes, i know i ask to many (stupid) questions.. you can call me 'smartass'
Sergio
#24
It's an inherent problem with the CBR1000F, the later design of CCT was better, but it didn't entirely solve the problem. I guess Honda just thought it would be too expensive to redesign the whole thing and once the bikes were out of warranty it would become somebody else's problem.
I don't think Honda have used this design on any later bikes, which speaks volumes. A version of this engine with gear driven cams like the VFR750 would have been the perfect engine in my opinion.
P.S. A 'smartass' doesn't ask stupid questions, they have all the stupid answers
But seriously, there is only one stupid question and that's the one nobody thinks to ask
#25
That isn't my worst fear. I fear that chain (if there is a lot of 'free play') might jump over few teeth on cam shaft sprocket and bend/break some valves, damage pistons, cylinders, etc...
#26
If you fit a Honda OEM camchain it may be better (doesn't have a masterlink)
BUT
Then you have to split the engine and you may as well do a complete engine overhaul.
The camchains we use can be changed in about 4 hours total.
You'd need a HELLUVA LOT of chain wear to jump teeth even without HenryM's modification.
They do stretch quite a bit though.......but because it's over the whole length of the chain, the movement on individual links isn't that much.
BUT
#27
I am pretty sure that some euro models came with only one headlight bulb.
+1 on the Cush rubbers being worn, I check mine whenever I replace the rear tire and so far they are nice and tight.
Another bike I had was so loose new from the factory that I actually had to shim them. Another manufacturer that shall not be named on this most prestigious of all forums.
#30
Ahoy there comrades! I was busy these days...
I must thank you all for your answers and advices. I am very grateful.
On the end i decided to replace the CCT. I will use stock one. After that everything should be OK in the next 50-60k km.
That means i don't have to worry and be afraid that noise will come back in the next 5-6-7years at least.
So.. I will replace CCT, CC, rear slipper-tensioner, put some mineral 15-40 or 20-50 oil and sync the carbs.
Also, i will replace rear cush rubbers to eliminate that 'click' sound and gentle hitch when changing gears...
I will do this on first days of spring, or maybe earlier if the weather let me
Expect a LOT of pictures
Special thanks to Mr. Naga_Thai for great HOW TO tutorials, tips and the time he spend to explain me everything i should know about this amazing motorcycle.
Wishing you all a Merry Christmas and a very Happy New Year! Hope you all enjoy your Holidays.
