R/R
#21
Kiwi JK
Re suitability for your CBR1000F = IT WONT WORK.
WORDS OF WARNING!!! (If you want further detail)...
Many people and sellers are ignorant of the fact that there are 2 types main of charging systems on modern bikes. They then make the mistake of believing that a Regulator/Rectifier (RR) from one bike will work on another bike.
There are two main types of alternator that are fitted to most bikes, each requiring a different type of regulator rectifier.
Our CBR1000F has a Field Control Type (FCT) and requires that specific type of RR.
Unfortunately the Hyabusa & Vmax RR referred to is designed for a Permanent Magnet Rotor alternator (PMR) and hence is not applicable to our CBR1000F.
#23
I know with the ingenuity of some people on this forum, anything is possible. From my perspective, however, it seems impracticable; when you consider the work and cost of replacing/redesigning the rotor, stator, wire harness and the RR. Maybe, from my view, just better to keep a quality charged battery installed and if ever need to replace RR then replace with quality unit as mentioned before.
#25
Just in case anyone runs into this thread with charging issues, I just want to give a quick +1 to changing the alternator windings (the thing that you can take off the side of the engine just above the clutch slave).
Mine static tested fine, but when running I would only get power on 2 of the 3 phases. Took me a while to find one at a decent price but swapped it over and all good now.
I'm still using the Bosch RE55 regulator (from a Torana, no less) and 3 rectifying bridges I bought from Jaycar/radio shack attached to a heat sink. about 15 thousand kilometres so far and it's rocking along
Tim.
Tim.
#26
on
Good alternate (excuse the pun) option there Tim
Do you have the Radio Shack rectifier part number ?
& yeah Naga Thai - that's my route with the bike - keep a
good battery in good condition in the bike and the RR won't
have to work too hard - bad batteries on the other hand are
akin to pointing a loaded 45 at the RR with a potential
ricochet hitting the stator field coils later... ask Shadow !
#27
As pointed out, the 3-phase system on these bikes are kind of special. Instead of magnets, it relies on an exciter coil that is spinning. I think I could get the one from e-bay to work but I can't look inside the OEM R/R to see what's going on in there. The ign key puts power to the exciter coil and the 3 yellow wires simply feed 3 different phase A.C. currents to the R/R where they are turned to D.C. and regulated before being sent to the BAT. What I am thinking is that inside the OEM R/R the keyed hot wire is doing more than just powering up the exciter coil. I think it is used to open a gate to let the rectified power travel to the BAT. (just guessing)
I am also think that the third white wire may be going to the exciter coil and the voltage is being checked off of it.
#28
This is what i used, 3 of em. - 400V 35A Bridge Rectifier - Jaycar Electronics
This is something that would fit the bill from Radioshack (actually at 50A you could only use 2 of them and waste a channel) - NTE NTE53016 Silicon Bridge Rectifier 200V 50A : Rectifiers | RadioShack.com
A quick description... all the rectifier does is convert the AC from the alternator (alternator - alternating current, get it?) into DC for the bike. if you put alternating current through a couple of diodes, you get Direct current! All a rectifier bridge is is a little box with 4 diodes in it.
So to use them, the rectifier bridges have 4 poles, 2 labelled '~' for the AC and 2 labelled '+' and '-' for the DC as you have 3 AC wires coming from the alternator you need at least 2 rectifier bridges (and half of one gets wasted) but I just splurged and bought 3 so that they are all doing half as much work. (I just split each wire from the alternator into 2 plugs and assigned one bridge to each wire)
So you just wire all the + pins together then into the battery (through a fuse if you are going to do it right) and the - pins all get grounded to the frame. then just plug the 3 yellow wires that come from the alternator into the ~ pins on the bridges. it doesn't matter if there is a spare ~ pin (if you are only using 2 bridges).
After riding for about an hour my bridges were real hot, so Bolted them all to a heatsink (not unlike this one - Versatile Heavy Duty Heatsink - 72mm Long - Jaycar Electronics) now they barely warm up.
This is the regulator I used on ebay. I had mine in the shed but you should still be able to buy them from auto parts shops. BOSCH RE55 EXTERNAL REGULATOR SUIT HK,HT,HG,HQ HOLDEN,LC,LJ TORANA GOODCONDITION | eBay (once the link dies just search 'Bosch RE-55') Thinking about it though, you could easily replace that with a regulator from radio shack and replace the whole R/R unit for about $20...
Tim.
Tim.
#29
What I am thinking is that inside the OEM R/R the keyed hot wire is doing more than just powering up the exciter coil. It would simply go to it rather than being diverted to the R/R.
I my example above, the rectified Power from the alternator goes straight into the battery, the RE-55 is fed power from the ignition, then into the field coil to earth. AS the voltage rises the RE-55 should drop voltage to the field coil, thus regulating the alternators output. At least, I hope that's what it's doing (it only ever gives me 14.1v before anyone warns me)
Tim.
#30
