question about engine Vibration
Old 07-21-2005, 09:43 PM
vortex1114's Avatar
Default question about engine Vibration
As you can see im new. ive had my 93 CBR 1000F for three years now. it runs perfect except for an engine vibration. it occurs at about 4500-5500 rpm. its not present below 4500 or above 5500??? i cant figure it out. i thought it might be the cam chain tensioner but the engine really doent make any abnormal noise, it just vibrates. anyone else have, have had, or heard of this problem? any help would be great, its just real annoying![:@]
Old 07-21-2005, 10:37 PM
SILVERBIRD's Avatar
Default RE: question about engine Vibration
hey, check your balancer shaft you can adjust the backlash on it. ill bet that is what it is. its very easy to do.
Old 07-22-2005, 07:34 AM
Hey, I've got the same problem same RPM's. At first I was a bit worried, but later I just ignored it. I changed the cam chain, but the vibes remained. Can you please describe how to adjust the backlash on the balancer shaft?
Old 08-01-2005, 05:56 PM
SILVERBIRD's Avatar
sorry it took so long to post if you need help this should work.
[IMG]local://upfiles/1033/56CA3A1E00464FFAAEE8612E4EAD7FB2.jpg[/IMG]
[IMG]local://upfiles/1033/2B7D986BC22D414882A0DB9CE1777437.jpg[/IMG]
Old 04-22-2006, 07:07 PM
did the suggested solution work?
Old 04-23-2006, 12:16 AM
I would like to know if this worked as well....since I've got the same exact problem. I to, have just been ignoring the vibes thinking it may just be how the bike is.....starts to make my right hand numb after extended periods in that RPM range though .
Old 04-26-2006, 05:39 AM
Seems like very simple [&:] Can I repeat this procedure if it would not help from first time (is it possible to repeat this procedure many times?) ?
Old 04-26-2006, 06:19 AM
dad's Avatar
dad
dad is offline
There is a little bit of a buzz around 5,000. The balance shaft doesn't take it all out and that adjustment just sets the gear lash. They can get noisy with age but it's as much the rubber cushions in it hardening as anything else.
Just a thought. If the bar end weights are missing or have been replaced with aluminum ones, that will contribute to an objectionable bar buzz. The originals are heavy steel, rubber mounted in the handlebar to work as a damper. Absent the weight, the vibration damping is absent.
Old 04-26-2006, 09:15 AM
R1000's Avatar
Last year I begin to notice vibrations at some occasions, escpecially at high lean angles, from the other bike I use . It showed up to be the drive chain that began to bind on some links. Perhaps your bike vibrates also when not moving and then it will be some internal thing and not the drive chain.
Old 04-26-2006, 08:54 PM
i have somewhat of the same problem. my bike vibrates/rattles at stops and low rpm's untill i get it above 4500. anyone know what this could be?
Quick Reply: question about engine Vibration
