Potentially silly Question (UK Specific?)
Don't worry harry , that's normal.
On dipped beam the left-hand bulb shines (left -hand side of the bike that is), looked at from a distance it can appear that both portions of the headlight are illuminated but if you get up close you can tell it's only one side.
Pop the full beam on and the right-hand side lights up as well so both sides are shining. You'll know when you've blown a bulb 'cos everything goes dark
![EEK!](https://cbrforum.com/forum/images/smilies/eek.gif)
Well, you've been on this board since Aug 07, so I assume that you've had your bike at least that long, and you're just noticing this now? My US bike currently has ony one bulb working on low (dipped) beam, but that's definately because the low beam is blown out on that bulb. So my guess is that you (and probably also hawkwind) have blown one lowbeam, unless the UK bikes are wired differently that US bikes, but sawnee's response makes me think otherwise. One way to check is to swap the two bulbs in your headlight and see if the same side remains out. If it doesn't, your low beam is blown. I know this is a pain in the ***, because to do this generally means removing your fairing uppers. I think Shadow or someone has claimed you can do it without removing the uppers, but getting the bulb retainer clips off with the uppers still on is, to me, almost impossible.
All the bikes with the twin headlights that were sold in Sweden had only one side low beam, double high beam. This was due to a traffic law stating that motorcycles could only have one lightsource on low beam. This has been lightened up (hehe) in tha last years, so I have done a conversion on mine so both lamps shine on low beam.
Fit blue tungsten halogen globes while you're at it, and remember the tabs on Honda bulbs aren't the same as normal "car" bulbs.
![Smile](https://cbrforum.com/forum/images/smilies/smile.gif)
Yup, you've blown one Harry - second is sure to follow so remove the panel and replace both.
