Poor running at low speed
Old May 3, 2008 | 03:54 PM
topi's Avatar
Default Poor running at low speed
Hi
My -90 sc24 (71 000km)running poor at low speed (2000-4000rpm).. "She" has new spark plugs, valve clearance adjust, carb synchronisation is ok.. What I shouldchek/do next, any suggestion?
-topi
Old May 3, 2008 | 06:04 PM
mikekop's Avatar
October 2009 ROTM
Default RE: Poor running at low speed
You´re probably looking at a carb cleaning job, but first, check that you don´t have any air leaks around the intake rubbers. Check by spraying start gas (aerosol) around the rubbers when the bike is running. An increase in idle speed will indicate air leak. My bike was running badly in that rpm range, and it turned out it was missing a rubber cap on one of the small tubes where the carb sync tool attaches, on the intake manifolds. I had my bike to a shop to check ignition, buying spark plugs, spark wires, spark plug caps (luckily not OEM Honda ones), and had the carbs off twice before I found that crap fault.
Old May 3, 2008 | 09:22 PM
MarkR's Avatar
Oooohh, I better check that. (cough as high reves)
My bike has bugger all power below 3k, but I think that's by design.
3-6 is strong, 6is a power band, 9-10.5 is lost of license if caught.
Old May 3, 2008 | 11:52 PM
Shadow's Avatar
Most CBR1000F's are low on power below 3000 revs - they are touring bikes, so not designed to run down at low revs. +1 on the leak check tho'
Old May 4, 2008 | 03:49 AM
topi's Avatar
Thank you for your answers!
I must check outairleaks withthat "start gas"-spray, but like you say Mikekop, I am afraid, that carb cleaning job is head of me;-)
cbrpaul
How To's
Aug 17, 2010 07:58 AM
fastspares
Mar 2, 2010 08:21 PM
derekdaniel08
Jul 25, 2008 10:34 PM
scoosh
Apr 14, 2008 03:12 PM
bryanut
May 24, 2007 06:30 PM
