An offer I couldn't refuse.
Old May 25, 2009 | 07:39 PM
Imo000's Avatar
Default An offer I couldn't refuse.
Well......... got an offer on the bike that was a lot more than I was expecting and decided to sell it. Two months ago, put it up for sale asking a lot more than other Hurricanes. I was firm with the price and figured it it doesn't sell, I'll keep it. I was hoping that it wouldn't sell but eventually had a buyer with money and appreciation to the excellent condition of the bike, buy it at full asking price. I got the $3000 CDN for it and he got the bike (with new rear tire and brakes, full safety certificate and ready for the road). I was very sad to see it go but the rider is mature so it went to good hands.
I put around 100kms before putting it up for sale, just to make sure everyting was working 100%. However 2 days after the sale he called me that every now and then the bike would stall while cruising. This never happend to me so I was just as supprised as he was. Sounded like it was starving of fuel. I stand by my work so I offered him (even though we both agreed that he was buying the bike as-is, no warranties) not to leave him hanging and try to figure out what is causing this problem. So far I've replaced the fuel pump bypass ruber line with a steel fuel line that I bent (with the proper pipe bender) to a nice U shape. I thought for sure it would resove the issue (the ruber line was pinching and looked like it was the cause of the fuel starvation issue). Two days later he called sayin hit's still the same but very random. Once it happend only after 5km of riding, then he let it sit for a few mimutes, the bike re started and ran fine for another 32kms. He sais that the engie runs fine untill all of a sudden it starts to loose power (I think it's running out of fuel) and then when he pulls over the engine stalls.
I'm starting ot think that maybe the fuel filter is clogged or the carbs need to be cleaned (they were drained when I got the bike but could be soem residue that got dislodged once it was driven in a warm wearther). My other theory si that the fuel tank venting system is not working properly. I wish I could see the problem as it's happening, tha tway it woud be easier to diagnose the issue. Either way I'll help the new owner out as much as I can to figure out what the heck is causing this. I thikn it's a minor issue but we just haven't found the casue of it yet.
Old May 25, 2009 | 10:59 PM
Shadow's Avatar
Tank fuel filter
Pinched gas line
Side stand switch...........?
Old May 26, 2009 | 08:39 AM
VeryMotley's Avatar
Sounds like venting is the issue. I had a venting issue, and it acted the exact same way.
Patrick
Old May 26, 2009 | 10:52 AM
Shadow's Avatar
If you find it IS a venting problem, I have an inexpensive way to fix it.
Old May 26, 2009 | 12:02 PM
sawnee's Avatar
Another way to check is to take it for a decent run and then take your helmet off and open the filler, if you hear it suck in air as you open it its a vent problem.
It could be pinching the vent pipe when the tank is refitted or maybe the rubber pipe has even blocked or collapsed.
Old May 26, 2009 | 02:38 PM
Imo000's Avatar
Thanks for all the help, I wil check each method. Read Shadow's post too and maybe drilling that extra hole might be the ticket. https://cbrforum.com/forum/showthrea...venting&page=2
Old May 26, 2009 | 07:14 PM
Imo000's Avatar
Got some encouraging(sp?) news from the new owner. I've asked him to change the fuel filter and put soem carb cleaner in the tank and appears it has worked. I'm hoping that that was it, or else next is the tank venting theory.
Old May 27, 2009 | 12:11 AM
Shadow's Avatar
Don't just drill a hole - send me a PM and I'll help, and guarantee it'll never block again.
Old May 27, 2009 | 05:24 AM
Imo000's Avatar
ok will do. If the problem is still there I'll send you a PM. Thanks!
Jeffcbr600f2
Feb 19, 2012 08:55 PM
KenG
Dec 22, 2011 06:20 PM
KenG
The Hurricane Saloon
13
Feb 5, 2010 07:16 AM
Juliet
Apr 28, 2008 09:12 PM
KidCr3nshaw
Feb 20, 2007 03:23 AM
