Newbie says hi
hi i'm from Derbyshire, England and a very proud owner of a 96 CBR 1000F had her for 6 months a love her loads, just thought i'd drop by and say hi.
[IMG]local://upfiles/3618/05016C16C6F4451896926DCB49B25C26.jpg[/IMG]
[IMG]local://upfiles/3618/823247D4011241BCB923660A693CF75F.jpg[/IMG]
Hi:
Another Newby to this site.
I too have A Honda CBR1000F Hurricane, but I liked the looks of the Jellymould newer, bike better, found a 93 doner bike, and converted my older bike to the newer look. what cha think.
Martin:
I had more problems getting the motor out of the older CBR than the newer bike. the fit was real tight on the side without the spacer/lock nut once I got that loose and all the bolts out she came out pretty easy , but I had the carbs off , water hoses off and the jack barely up under it and it did not move. I removed the six bolts on the front of frame/engine, still was no movement, I loosen the rear engine bolt with the spacer lock nut and it almost fell out of the bike. So I did this with the newer frame motor and removed the bolts and it came out a lot easier than the older frame as I said before. So you may want to try that. if you want another pic or 2, send a place where I can email to you as the pics are to large in orig format to post here. Good luck on getting that motor out.
Cheers Mate!
Cheers Mate!
Hi guys, if you want to see larger pics just click the thumb nails on top of the page!
or go here South Derbyshire Riders or here Bike pics
