new here and need advice
#21
#22
is there any other options for a upper fairing. i was looking at a 900rr upper fairing. they look close but im assuming that it wouldnt work without a lot of mods to get it to fit right. i looked in the alternate part section theres a lot of info but not much on fairings, damn these hard to find parts.
#23
The manual advises cylinder pressures of 150-206 PSI at 400 RPM.
Don't be too concerned if they're slightly lower than this though as long as they're not too dissimilar. I've been running my '91 with compression readings of about 125 ish for two years and it hasn't made a jot of difference to the kick up my **** when twisting the right hand.
Good luck. Your call if you buy it. It's a gut thing.
#24
If that noise is a vacuum leak, the first thing I would check is the rubber plugs for the sync ports. They can fall off, and then you have a major vacuum leak. After I did a sync on mine, I dropped one of the little buggers under the carbs and never found it. I had to use a rubber plug from my Jeep.
#25
#26
well guys i went and done did it. i bought the bike. picked her up for 425 bucks. and even got a haynes hardback manual to go with it. the bike has 39000 miles on it. read it wrong when i looked at it last. i figure if i cant get her running right then i should be able to part it out and get my money back, i hope. think its going to need some new tires. but i get to get her running right first. ill post up some pic of her in the next couple days.
#27
well i just got back from a 2 hour trip to pick up a parts bike. most of the plastics i needed are on this one and it has brand new tires. its a 90 though so a little bit different but it will work. the bike has 75k miles and no title but it was worth the 300 bucks. ill get pics of this one later. 2 bikes in one day im not sure if i just wasted money or if i got a deal only time will tell
#28
#29
Guest
Posts: n/a
#30
thanks guys for all the help and comments so far i will try and post some pics tonight of the two bikes. i have off tomorrow so im going to start pulling the fairings on the 90 and start doing some body work and hopefully maybe my dad can come out and help me figure out this damn carb problem or vacum leak. i want to ride her. need to get it done
