New guy tire help
Old 06-11-2011 | 06:31 AM
MadHattr059's Avatar
Just replaced the steerring head bearings on my 98CBR600F3. If yo do this, be sure to get tapered roller bearings NOT the factory OEM ball bearings. If you use taper-bearings it will be a one-time repair for the life of the bike.
The actual removal/replacement of the bearings is fairly easy to do. The dis-assembly to remove the stem to accomplish that is a major task. You basically take apart the entire front-end of the bike. I had to pull the tank, airbox, and ducts as well to be able to slide the stem out of the frame.
The skills need are fairly basic, it just involves a LOT of taking apart and putting back together. There are a couple of good walk-thrus in the how-to section and on-line.
The only 'specialty tool' you need is a piece of 1/2" all-thread (about 10' to 12") and 2 nuts and 2 heavy washers for it. You use this to simultaeneously pull both new races straight in to the stem mount on the frame.
Set aside about 4-5 hours to do the whole job with-out rushing from start to finish.
Ern
CBR327
04-19-2012 08:34 PM
Wants a CBR
06-23-2010 01:23 AM
LaughingMan600F4i
05-29-2009 02:11 AM
cbrmarshall
11-14-2006 06:57 AM
