My starting problem
Old Jun 12, 2010 | 06:13 PM
  #41
TimBucTwo's Avatar
Originally Posted by CyberTrip
Update!
Wow! So I bought a compression tester and also checked the spark plugs for spark.
Results:
Cylinder1: Spark - PASS
Compression - 60psi FAIL
Cylinder2: Spark - PASS
Compression - 30psi FAIL
Cylinder3: Spark - PASS
Compression - 130psi FAIL
Cylinder4: Spark - PASS
Compression - 15psi EPIC FAIL
WOWsers! I think you have it. Those compression readings that you are getting are ****-poor. I would definitely check the valve lash. I guess they are to tight and loosen up when she heats up. I would tend to go this way because, the temp. of the engine will not effect bad rings. To prove the case, check the compression with the bike cold and then hot. I bet they changes.
Old Jun 13, 2010 | 12:48 AM
  #42
CyberTrip's Avatar
The bike being hot/cold absolutely makes a difference. If you see my videos you will see that after the bike has been warmed up by actually running for a while that it will start like there's no problem. If I put a halogen lamp on to the engine it starts up easier as well. That tells me there is definitely a difference in compression depending on temperature.
Old Jun 13, 2010 | 02:18 PM
  #43
TimBucTwo's Avatar
CyberTrip, have you adjusted shim and bucket valve lash before? If not we can help you through it.
Old Jun 13, 2010 | 11:39 PM
  #44
CyberTrip's Avatar
No, but I have read the how to on valve clearance here and I also have the service manual. Any tips would be appreciated.
Old Jun 14, 2010 | 02:24 AM
  #45
CyberTrip's Avatar
Checked the clearances on the valves. All the intake valves are out of spec by at least .003 inches. They were too tight. The exhaust valves were off spec by .001 inches. They were too tight as well. Tomorrow I will work on getting them all set correctly. Hopefully this fixes the problem... If not... I'm very close to just parting it out. I've got my eye on a 2006 Suzuki SV650S which I am probably going to get anyway.
Old Jun 14, 2010 | 12:23 PM
  #46
happy_charly's Avatar
ah i just set my valves last week its a breeze
Old Jun 15, 2010 | 12:08 AM
  #47
CyberTrip's Avatar
All done setting the valves. Put her back together, broke a bolt on the valve cover while doing it, gonna have to get it drilled out and get a new one put in. I checked the compression and they all pass now! Also, the starter doesn't sound like it's dying anymore. It sounds like a normal start. I took her outside and engaged the choke and she started right up! Took her for a spin and boy does she perform better than ever! She spits out some oil where the bolt had snapped off because it's not sealing but that's just a minor set back until I get the repair bill for it.
Anyway, all is well again! I'll take video when I've got light out with my new Kodak Zi8 HD Camcorder.
Thanks everyone for your help! I should have checked this from the start.
Old Jun 15, 2010 | 03:10 AM
  #48
wolfman 1000's Avatar
Bummer about the bolt but great news about the rest man, glad it's sorted for you.
Old Jun 15, 2010 | 08:52 AM
  #49
CyberTrip's Avatar
I think the bolt may come out with an extractor. I didn't put much torque on it. My torque bar was set to 7ft-lbs and it twisted off before it even clicked.
Old Jun 15, 2010 | 09:50 AM
  #50
bicklebok's Avatar
Happy for you!! Putting some new life in the old girl!!
