Is My Sprocket FU(KED?
I'm thinking I may change the front sprocket anyway , waddaya think?
You should not change just the front sprocket. Both sprockets and the chain wear as a set. As the chain wears out it gets longer and the pitch changes. It wears the sprockets accordingly. If you change just the front sprocket you will get accelerated wear from the stretched chain and have a worn out sprocket in no time. This would be a waste of money.
Guest
Posts: n/a
Hey Hawk... if you are down to a choice between thinking its a gear box issue or a front sprocket issue ....mate, ...just bang a new from sprocket on , adjust the chain nice and give her a short test run to eliminate at least the drive line as a possible issue first before getting into any type of gearbox panic ...
I'm starting to think all my problems may be related , the odd wear on the side of the sprocket , the shake on the bars when riding with no hands , the apparent chain slip . TimBucTwo suggested the rear wheel being out of alignment .
I think I'm gonna have to go over everything , from chain tension to wheel alignment and see what I come up with
I have to add that the front sprocket is lacking lubrication. Did you clean it before you took the pictures? What are you using for chain lube? There looks like some kind of fluid in the small tapped hole.
Also, you can check for chain wear by grabbing the chain with two rags and checking how much side flex you have on a slack chain. There should only be ½” (12mm) or so.
