My Hurricane is screwed again
Old 10-01-2009, 11:22 PM
JHouse's Avatar
I also drive one of those Kubota RTVs a lot at work, so I just fill the tires with slime and don't worry too much about flats anymore.
They make slime for bikes now, too, but I don't know how I feel about that....
I tried that stuff years ago, probably a different formula and under a different name, but it tended to pool at the bottom while the bike sat and when you got going again you were hopping like a roo.
  #23
Old 10-02-2009, 06:47 AM
cbrsixpack's Avatar
November 2009 ROTM
lol.............burnt big TIME
  #24
Old 10-02-2009, 08:09 AM
Shadow's Avatar
I don't take them off the rim -most bike shops here use some stuff that's like washing up liquid, a bit sticky - getting one off at home is MAJOR bloody PT ! I use one of those rubber string things, use plybond in the hole, cut off the excess with a razor blade and I'm good to go.10 mins tops and I've never had one fail................
Bugger for punishment is our Steve-o !!!!!!!!!!!!!!
can I send you some rubber stringy thingies mate ? You can buy your own bloody plybond........HEHEHEHEHE
FARK ME, 60 CLAMS FOR A REPAIR KIT.....................
buggers saw you coming I reckon.....
So $105 later .....................Arrrrrrrrrrrrrrrrrrrrr !
BTW IDODIRT did a how to on the old forum, if you can find it, or maybe a PM...............
  #26
Old 10-02-2009, 08:44 AM
Shadow's Avatar
Buy the kit with the Hole tool, and the Plug inserter tool mate. About $10 AU I use plybond to hold it in. I carry a can of that instant puncture fix under the right rear fairing, in front of the CDI unit - fits a treat..............
You could probably have got away with just a shot of puncturefix if the hole was that small................you'dve been riding in 5 mins
BUGGER !
  #27
Old 10-02-2009, 09:31 AM
JHouse's Avatar
Steve, Given your approach, it sounds like you were working by the hour plus a parts mark up.
  #28
Old 10-02-2009, 11:36 AM
SamkFL's Avatar
i have two external plugs on my cbr's rear tire.i run my bike fast as soon as the puncture is repaired,ok max 160kph.no problems so far.
  #29
Old 10-02-2009, 12:30 PM
Shadow's Avatar
I thought you said fast, Sam ? hehehe
On your roads that IS fast................
160 anywhere in your country is quick indeed...........
  #30
Old 10-02-2009, 01:59 PM
dietDrThunder's Avatar
I agree with the guys that say to plug. I have plugged two of mine with great results. One did still loose some air at about the same rate of one leaking at the bead. I did not have to re-balance. Why take it to the shop? Any auto supplier has the plugging tool and plugs. I use the rope type. I have had better luck with the rope type than the rubber plug type. I think it is because the hole may not be round and the round rubber plug will not conform to the hole like the rope.
Right...that's why part of the procedure on installing the mushroom type is to round out the hole first. Both work fine though.
Quick Reply: My Hurricane is screwed again
