Lower fairing attachment
Old Aug 11, 2019 | 01:31 PM
JohnN's Avatar
Default Lower fairing attachment
Hi,
i have a 90 1000f that I just purchased. It has an aftermarket exhaust and the lower fairings are flapping. The bottom of the fairing is not bolted into anything.
The center stand has also been removed. I’m trying to return it to stock, but I can’t figure out where the lower bolt of that fairing goes.
Does it somehow bolt into the center stand mount or the factory header?
I’m in the process of ordering parts and this puzzles me.
Thanks,
John
Old Aug 11, 2019 | 06:31 PM
wooferdog's Avatar
Hey John,
Welcome to the forum.
The lower belly pan pieces are attached to some outer tins that hide the exhaust pipes before the mufflers. Aftermarket cans usually don't have any provisions for using these tin pieces, so they have to be removed, which leads to your problem.
Honestly, I don't have an answer for that.
Center stands can be found on ebay. Where are you located?
Old Aug 11, 2019 | 07:12 PM
JohnN's Avatar
Thanks for the info.
I found a center stand and all the exhaust bits on eBay. I now see the rear lower bolt attaches to the exhaust heat shield.
I’m in Ohio.
Turbulenz
Mar 24, 2017 03:41 PM
hurricanematt
Feb 22, 2014 11:12 PM
JIMMY02F4I
Jan 18, 2009 05:14 PM
tobiahr
Sep 13, 2008 12:36 PM
supercosta3
Jun 28, 2007 10:05 PM
