Loud pipes save lives!
I'll do my best, mate ... I'll get my lad to post it up when they're fitted
They should be here sometime tomorrow, got the tracking number a couple of hours ago ....
I've also noticed, they've gone up in price by £50 since last night!!! Good job I ordered them when I did!!!
on
Generally speaking and not just with Delkevics but any pipes that replace stock and
have more flow and less back pressure require a set of larger jets and or shims as I
found out when I had one of my bikes on the Dyno last week.
Stock jets with hi flow pipes ='s lean running at mid to high rpm and less ponies as a
result
Just got two jet kits with shims yesterday and also found two racks of carbs locally
for short $$ - going to kit them out and install soon.
result
@ Twig,
I'm sure that what Sprock has said is correct, and I suspect my bike may have been running a little rich to start with .... all I can say is that it now runs sweet and crisp, with no flat spots, all the way up to the redline.... pulls like a train too! I'll no doubt, have it checked on a dyno soon... just to be sure, tho I'm really happy with them and have no regrets whatsoever.
PS .... if you do go ahead and get a pair, just check that your collector box isn't rotten first ( mine's stainless, so wasn't an issue..... otherwise, you might find you have extra expense.....
Regards,
shakey
Regards,
shakey
QuinC
04-27-2006 05:03 PM
