SHE LIVES! (with video)
Finally got 'er started again. Plugs were hopelessly fouled. And as normal, the first time doing any thing took forever (2 hrs to get the plugs out, 15 minutes to get em back in).
Opinons? How does she sound? There is a slip on exhaust (no name that I've found).
http://www.youtube.com/watch?v=tB4iCBfMHIc
Err... fraid it's not. The petcock on my bike goes Forward -> Down -> Back from the PO. I haven't a friggen clue which position is which. I'm assuming somehow they somehow installed it a quarter turn counter-clockwise
Shes comin together! As long as you follow the turn plug till tight and then the 1/8 or 1/4 turn there's not much else you can do. I need to check on mine from last year just to double check they are still tight. These things run some high rs so its not a suprise for plugs to loosen up over time. #1 was loose in my F4i when I changed them out (yikes!)
