Leaking Petrol..........Help
Old May 22, 2009 | 11:06 PM
Aussie Johnno's Avatar
Ride of the Year ... Just Ask The Boys
Default Leaking Petrol..........Help
Hi Everyone,
I rode the bike last week, no problems, Started the bike today and is leaking petrol from what looks like an overflow pipe that comes out of the carby and down in front of the air box (there are two of these pipes) but only one is leaking (left side).
The only things i have done
1. adjusted the crank balancer (not related)
2. checked the air filter
I checked to make sure i had not crimped any breather hoses, all clear.
It also sounds like the bike is idling with the choke full on when it is not
Any ideas
Thanks
Aussie Johnno
Old May 22, 2009 | 11:32 PM
Imo000's Avatar
Is this the little hose that is connected to the bottom of the filler cap?
Old May 22, 2009 | 11:47 PM
The two pipes come from the inlet side of the carby and down in front of the air box, not connected to anything just venting to the air.
Aussie Johnno
Old May 23, 2009 | 02:17 AM
Shadow's Avatar
Tap the carb float area with a piece of wood and a hammer - may just be a stuck float.
Also check the hose that connects to the tank - it would run down in the same area ........
Old May 23, 2009 | 08:20 PM
bluebeard's Avatar
Certainly sounds like stuck float. As Shadow said give a tap with a block of wood. If it doesn't work you may have to remove the carbies & reset the float levels. They do alter over a period of time. It can be done in about an hour & is not that difficult.
Harry_T_Hamster
Nov 15, 2009 07:45 PM
cbrsixpack
Jul 12, 2009 02:51 PM
just4u2
Jul 7, 2007 03:07 PM
MarkR
Sep 24, 2006 10:16 AM
morpheous283
Mar 15, 2006 08:53 PM
