Leakdown tester
Old Dec 3, 2007 | 02:00 PM
R1000's Avatar
Default Leakdown tester
This weekend I put togheter a simple leakdown tester from standard air toolcomponents. The meters are interconnected by a1 mmair passage.The principle is simple; the left meter shows a reference value e.g. 100 PSI and the right meter shows the outgoing pressure.If it reads 94 PSI the leakage is 6 percent. A race engine should only have a very few percent of leakage. I normal car engine may have 5 to 10 percent and more than this showes something is wrong.
[IMG]local://upfiles/4562/5551C6FB26D446B89924513E9EC05D38.jpg[/IMG]
[IMG]local://upfiles/4562/B240681EA95349EDA0384C543033E450.jpg[/IMG]
Old Dec 4, 2007 | 06:44 AM
Bennoh's Avatar
Default RE: Leakdown tester
Am i correct in assuming that the hose plugs into the spark plug hole ? Like a compression tester tool ?
What causes the leakage ?
Old Dec 4, 2007 | 08:23 AM
malbojah's Avatar
Leakage by the piston rings, or by the valves, or through the headgasket.
crlydave
Feb 10, 2012 07:09 PM
Bear600rr
Feb 12, 2009 12:12 PM
KidCr3nshaw
Feb 15, 2007 04:45 PM
civichatch
May 18, 2006 10:49 PM
