Jets needed
Old Aug 1, 2008 | 11:02 AM
sawnee's Avatar
Default RE: Jets needed
I have taken your advice and kept the air box. The other problem is a sticking throttle when the bike is hot, the cables seem ok and the only way to bring the revs down is to almost stall the bike.
Old Aug 3, 2008 | 06:11 PM
vl5150's Avatar
I would pull the the carbs, inspect and clean. Won't take too long. Lube the cables too.
Old Aug 3, 2008 | 06:12 PM
vl5150's Avatar
On the carbs, check the spring loaded rail for function too. On mine, I replaced a cracked carb body and had binding after I put back together. It was those pesky springs.
Old Aug 4, 2008 | 02:34 PM
sawnee's Avatar
I have lubed the cables (no differance)
I will check the springs tomorrow. Cheers.
Old Aug 4, 2008 | 03:07 PM
TimBucTwo's Avatar
Today I pulled the K&N air filter that I just put on the bike. The bike needs to be re jetted with it and I am not going to do that for an air filter.
Edit: It has rained here every day. It is pouring out again today. The weather report said that during June and July there were 8 days of no rain. It rained here on those days. Last Saturday I rode 10 hours in a down pour. When I say rain I am talking high winds and hail. This really sucks.
Old Aug 4, 2008 | 11:11 PM
Shadow's Avatar
Time to relocate, T B T ?
I'd go insane in those conditions...........[X(]
Why rejet ? What pipes are you running ?
Old Aug 5, 2008 | 08:14 AM
TimBucTwo's Avatar
I have a TB slip-on. I guess I can either install the TB or the K&N but not both.
It is to lean with both.
Snapp
F2 Tech
Apr 12, 2011 09:57 AM
steezin600
Jun 9, 2008 08:33 AM
sloppyjones
Jun 1, 2007 11:19 PM
