I may have killed my bike
Old Jun 23, 2007 | 11:34 AM
Triangle's Avatar
Default I may have killed my bike
About 3 weeks ago,the enginestarted making newnoises... It sounded like a fan belt was flapping around so I checked the oil... it was a bit low sotopped it up and the noise was gone... I rode it to work and back (25km)with no troubles. Next day the noise was back. The oil was low again but I couldn't see any leaks so I topped it up again. Sounded fine...I rode up to 1770 to meet waz57to buy his old seat off him (300km)... when I got back the oil level hadn't changed but I did notice the wheel was spinning while idling on the centrestand in neutral. I decided the change the oil and filter... refilled it with 3.8L as the manual said but didn't bother to check the dipstick before I started it up to idle and warm up.
While it was running and slowly spinning the rear wheel in neutral, I oiled the chain. The exhaust popped 3 times... about 3 seconds apart then ran real roughfor long enough for me to blip the throttle the get it to idle properly again but instead thethrottle flooded it andstalled instead.
I checked the dipstick and the oil was nowhere to be seen. I poured in the last 200ml from the 4L bottle and that got it half way up the dipstick.
I suppose that means it was running with oil below the min on the dipstick for about 2 minutes. Now, it will try to start but seems to only be getting one cylinder to fire.
I figure it can't be seized otherwise it wouldn't be turning over
Any thoughts?
Old Jun 23, 2007 | 12:41 PM
R1000's Avatar
Default RE: I may have killed my bike
Don't panic I don't think you have runned the engine with to little oil. The different oil levels can be normal and just the result you get by checking the oil directly when the engine has runned. I would start to check the plugs and change them if that hasn't been done for a while. If that doesn't help, I would check the valve clearances. If those are OK I would take the carbs apart, you may have a leaking float valve.
Other may come with more and better ideas.
Old Jun 23, 2007 | 10:20 PM
Trips's Avatar
Like he said I wouldn't worry about the oil level. Bikes actually only need about 500ml to a lire of oil to run. The rest of the oil is just to help cooling and cleaning. I had a GXS250 that went through oil a lot. I couldn't be stuffed checking it every day so I would just ride it until the light came on.
The wheel turning in neutral is normal when on the centrestand. There is always a small amout of drag.
I'd say you just have dodgy fuel/carb problem.
Old Jun 25, 2007 | 10:02 AM
Latsky's Avatar
Don't stress to much!! Change all the plugs and make sure that the filter is clean!! make sure the timing is fine it is possible that somehow the timing went out and that is why she was backfiring!! Clean all the fuel supply if you can, this will help lots!!
Old Jun 27, 2007 | 09:48 AM
Triangle's Avatar
yeah you're all on the money with it being a fuel problem... turned the tap to reserve and it started fine...[>:]
at least now I know the engine can survive with low oil better than with low fuel
Old Jun 27, 2007 | 10:15 AM
Latsky's Avatar
I am glad you got her to start man!!!
Old Jun 27, 2007 | 07:38 PM
waz57's Avatar
Len I bet the fuel was from a United dealer ?? I WILL NOT USE UNITE DIN MY BIRD !!! I recall I had just about the same problem with my old red bike she used to kill plugs all the time so I stopped using united fuel put a couple of bottles of carby / injector clean and I bet when I fire her up today first time for a number of weeks she will kick first time. Try a new set of plugs too as I bet they are glazzed.
Old Jun 28, 2007 | 08:05 AM
Triangle's Avatar
i always use caltex... there was nothing wrong with the fuel... just the reserve tank was needed...
Old Jun 28, 2007 | 09:51 AM
waz57's Avatar
I know I read your last post and had to laugh, but I just wanted to let you know about my eperiance with Untied and my local bike dealer had a few bad reports as well
515KKCO
Jul 5, 2013 04:09 PM
Wisconsin
Street Skills
Jul 19, 2012 03:22 AM
FLYOU
Oct 8, 2008 11:25 AM
allan99f4
Oct 6, 2008 01:34 PM
brancart1
Dec 8, 2005 03:22 PM
