hurricane startin problems
Old 06-12-2007, 01:05 PM
GARMIN1000F's Avatar
Default hurricane startin problems
88 1000f
just wont start, fuel is getting to the cylinders and the motor turns over it just doesnt fire up. However i can push start it and it runs fine.... what the hell could it possibly be?
bad battery?
bad rectifier?
Old 06-12-2007, 01:25 PM
R1000's Avatar
Default RE: hurricane startin problems
It sounds as the battery has retired. Measure the voltage across the battery at 5000 rpm, it should read about 14 volt. If it is lower, like only 12 volt or so,the battery is real bad or there is a charging problem. If it runs OK for quite a distance after a push start, itappears thatthe battery is bad. A bad battery can take the R/Rdown, so avoid running on a bad battery, they are far cheaper than R/R units.
Old 06-12-2007, 03:04 PM
Honda_Hurricane's Avatar
The battery. Common Hurricane problem.
Old 06-13-2007, 02:24 AM
So does it help to keep a trickle charger on the battery when not riding for more than a few days? (I usually clip the charger on after a few days parked) Or do the standard wet batteries just die out after a season or two? What do I gain with using the newer more expensive dry cell models? 87Hurricane
duececivic
09-25-2009 02:46 PM
isolated1523
07-09-2008 01:15 AM
simmadown
07-16-2007 09:15 PM
wilson_p_F4i
02-25-2006 08:23 PM
Quick Reply: hurricane startin problems
