High Speeds
Old Dec 14, 2007 | 02:36 PM
edccbr1000's Avatar
Default High Speeds
i was wondering if anyone has the same problem as i do. between 95mph and 115 my bike shakes bad. any suggestions to fix the problem
Old Dec 14, 2007 | 03:08 PM
honda502's Avatar
Default RE: High Speeds
Don't go that fast, or you probably need a new front tire.
Old Dec 14, 2007 | 05:13 PM
ArTravlR's Avatar
YG2BSM!
Check the air pressure in your tires, be sure your tires are in good shape & are not too old. Are the tires balanced? Many jackleg MC shops do not balance tires & will tell you it is not needed. When was the last time you changed your fork oil? Are the forks seals in good shape? Has the bike been in a wreak? Is the rear wheel & chain aligned properly? Do you have a sticking brake caliper?
Let us know what you find.
Robert Bashaw
LoweST Arkansas
www.ridehsta.com
CBR1000F
ST1100A2 STovokor
VFR800A5 Interprize
Old Dec 14, 2007 | 05:39 PM
Trips's Avatar
Scalloped or square tyres
Incorrect pressures
Mismatched tyres
Bad road surface or excessive road camber
Air buffeting from sidewids or vehicle in front
Steering head bearings
Swing arm bearings
Incorrect suspension setting
Being a fat bastard
Dodgy suspension
Gripping handlebars too tight
Could be any of those, but 90% are the 1st 4.
Old Dec 14, 2007 | 06:47 PM
dad's Avatar
dad
That sounds like perfect range for wheel balance problems. Check everything but suspicion is wheel balance first.
Old Dec 17, 2007 | 04:09 PM
TimBucTwo's Avatar
I can add one more to the list.
Are the fork tubes twisted in the clamps?
If the bikes hit anything and the triple clamps are either bent or twisted you may get a shake.
Bad mojo just plain sucks.
If it were me I would check or replace the fork oil as that is the easiest and then check the balance as dad suggested.
Being an extremist I would replace the front tire. If the bike was sitting it may have a flat spot in it. That would act like an imbalance while still being balaned.
EDIT: (sp) I type with two fingers directed by one brain cell. It can get a little messy.
Old Dec 19, 2007 | 03:08 PM
edccbr1000's Avatar
i got some new tires not but a month ago and replaced my forks about a year ago. how offend doi need to replace my fork oil. its not shaking to bad now that i got the new tires thats probably what it was.
Old Dec 20, 2007 | 03:16 PM
Griffin's Avatar
Mine is solid and straight with no shake, shimmy or roll up to about 130 mph which is fastest I've taken it.
Old Dec 27, 2007 | 12:27 AM
Shadow's Avatar
I've only replaced my fork oil once in the past 3 years, and regularly run the bike to over 150MPH with no problem.
itlnF4I
Oct 29, 2013 03:15 AM
Preid
Nov 17, 2009 11:30 AM
boblasek
Sep 17, 2008 08:34 PM
mattstunt929
Jun 9, 2007 09:14 PM
ThisisMickey
Dec 16, 2006 09:33 PM
