hi and help rear brake caliper
Old Aug 1, 2009 | 05:08 PM
ozzie1000f's Avatar
Default hi and help rear brake caliper
Hi guys and thankyou for a informative forum.I am the proud owner of a 94 1000f with 40000km"s and its a great bike.However there is a problem with the rear brake caliper.
The rear wheel is tight hard to turn the pads appear to tight on the disk.I removed the caliper and lubricated the 3 pistons put back together but when i tighten the 3 bolts the wheel wont turn.? When i depress the rear brake pedal the centre piston comes out but the other 2 either side remain stationary and when i press one the other seesaws?is a part missing that seperates that block from the pads?Any advise appreciated.Only problem i have..Many thanks
Old Aug 1, 2009 | 06:25 PM
malbojah's Avatar
Ok, here the quick and dirty: Your front and rear brakes are connected. When you press on the rear brake pedal, the center piston on the rear caliper comes out. When you push up on the 'secondary master cylinder' (left fork, above the fender), that pushes the outer pistons on the rear caliper. It's Honda's way of saying "We know you don't know how to use the brakes properly, so let us help you by screwing it up completely."
Eventually, Shadow (our local welcome wagon) will hopefully come by and post up a link to the service manual. Download that and look at chapter 13 or start at page 181 for the braking system.
Are you sure the rear wheel is straight in the swingarm?
Old Aug 1, 2009 | 08:03 PM
ozzie1000f's Avatar
Thanks for the link to the manual.Yes the swigarm is all good.The problem is that when i tighten the three bolts on the calliper it stops the wheel from turning.I checked the micro of the rear brake and i cant see any spacer between the brake pad and the calliper block...
Old Aug 2, 2009 | 12:18 PM
TimBucTwo's Avatar
I also have a '94.
The caliper butts up against the swingarm. The larger spacer goes in the wheel against the wheel bearing and caliper. That is the proper spacing. If it is still tight the pistons are not all the way in or the pads are the wrong thickness or not properly seated.
My bet would be that they are not seated correctly on the ends without the bolts passing through. There is a little clip thing that they sit in and it is difficult at times to get everything in the correct place while reassembling them (part #3).
For bleeding the LBS look at my signature for the link.
Old Aug 2, 2009 | 12:29 PM
TimBucTwo's Avatar
If you push on the two outer pistons, they send fluid back to the secondary master cylinder through the proportional valve. If you can't push them in the proportional valve may be plugged. You can test it by opening the top bleeder while pushing the pistons in. If they go in the valve is plugged or stuck.
Old Aug 2, 2009 | 04:12 PM
ozzie1000f's Avatar
ok thanks..the centre piston i canpush in no problem.THe left and right seesaw push one down other goes up.I have tried using a clamp but CANT get them to sit all the way in..You think this is the problem then?Appreciate this advise
Old Aug 2, 2009 | 10:10 PM
TimBucTwo's Avatar
Yes, all three should be flush with the backing surface before reassembly. Try using a flat piece of steel and a c-clamp to get them in. If they are not going in, you may have to pull them out and clean them. There may be some pitting or rust that is stopping them.
3v1lj03
CBR1000F Wanted / Swap
Jun 12, 2011 08:16 PM
garyboy_palaboy
Feb 4, 2010 08:52 PM
Zach
Apr 15, 2009 05:09 PM
wishin4600rr
Jul 7, 2008 07:36 AM
Err
Jun 21, 2006 05:38 PM
