Hey all New Member CBR1000F Brake light
Old Jun 24, 2023 | 02:49 AM
Mic J's Avatar
Default Hey all New Member CBR1000F Brake light
Hi everyone I have I have an 88 CBR1000f
Brake light works when rear brake is engaged.
Does not work when front is engaged.
Any tips on testing if its the switch or the wiring.
Thanks
Mic J
Old Jun 24, 2023 | 07:38 AM
rockpool's Avatar
Wiring diagram is at the back of the service manual
https://www.dropbox.com/s/1j8lmf5aqv...anual.pdf?dl=0
you should be able to pull the connectors off the switch on your brake lever and use a multimeter on the switch in continuity mode to check if it works - You should also hear it click when you pull it. Sometimes with adjustable brake levers the travel isn't enough so open the handle to its longest travel and try again if there's no click.
If you want to test it further (or don't have a multimeter) - jump the two connectors with a paperclip to simulate pulling the lever - the brake light should come on.
Old Jun 25, 2023 | 01:58 AM
dmoh's Avatar
The switch has two little connecting prongs to the wiring:
The connections can easily be dislodged. They are also prone to corrosion. They're also very fiddly to clean.
Good luck.
PS Nice bike!
PPS Mic, where are you in Oz?
Old Jun 27, 2023 | 07:56 AM
Pretty sure it will be the switch, as Rock suggests jump the leads to make sure.
Easy to fix and for once cheap to replace.
cbrandy1060
The Hurricane Saloon
Jun 27, 2023 08:13 PM
adapt63
Mar 21, 2014 04:16 AM
sneek24
Jun 2, 2012 11:43 AM
ohg35
Jun 22, 2006 06:35 PM
tutman6
Apr 7, 2006 02:00 PM
