Hello and help!
Old May 5, 2013 | 03:54 PM
catworst's Avatar
Default Hello and help!
Howdy all, new member with a problem. Had my 88 thou for nearly a year with no major problems, but last week it started to play up. When accelerating hard the bike seems starved of fuel, if I accelerate slowly will play ball but only up to about 60mph. Kinda feels like the main jets are full of crap but won't clear.
I suspected the fuel pump at first so have removed that but it has made no difference.
Any ideas?
Old May 5, 2013 | 04:58 PM
Bugkiller's Avatar
July 2014 ROTM
Question carbs?
Hi,
without hearing your bike I would suggest either fuel line/filter or the carbs.
Have you checked the lines are ok? Is there a filter fitted, if so is it clean? Are the carbs in need of synchronising or cleaning?
Rich
Old May 5, 2013 | 09:05 PM
Sprock's Avatar
Vacuum in tank due to tank breather blockage ?
Old May 6, 2013 | 03:06 AM
kiwi TK's Avatar
Crazy CBR Salvage Guy. RIP
Why do they keep blocking, it seems to be a common fault with no reasonable explanation as to why it happens?
Old May 6, 2013 | 04:44 AM
Strek's Avatar
Does your gas tank have any rust in it?
Old May 6, 2013 | 05:35 AM
Sebastionbear1's Avatar
Did you see that catworst, they all jump in and try to help without so much as a by-your-leave.
I guess I'll have to do it.
Welcome to the CBR Forum catworst.
Now to the problem. Probably filter based, if you switch the petcock to reserve is it better? If so, gunk in the filter. If not, may be some sh*t in the carbies, which may require a rebuild. Then look at the electrics.
Cheers, SB
Old May 6, 2013 | 04:29 PM
catworst's Avatar
Thanks for the welcome. The tank isn't vacuum locked and appears to be rust free. The bikes runs rough with the tap in both positions. I sprayed some carb cleaner in and it seems to be slightly better but still no where near right. Gonna get it to a mechanic as it's beyond me really.
Forgot to say, my bike has no fairing so I've no idea which was in on and which is reserve!
Old May 6, 2013 | 08:52 PM
Sprock's Avatar
12 oclock is on , 3 oclock is off 6 oclock is reserve.
Well no vac lock leaves a thorough carb cleaning mains , pilots , pilot needles and
most often forgotten about ........ the float valve screens
Also check the carb diaphragms for rips or tears and don't let carb cleaner near them.
Old May 8, 2013 | 11:37 AM
catworst's Avatar
Thanks Sprock, gonna get them cleaned out and see what happens from there.
Old May 9, 2013 | 07:10 AM
wheelnut's Avatar
Welcome Crew
have a look at this
https://cbrforum.com/forum/cbr-1000f...eryone-145696/
