Fuel pump issue
Old Sep 13, 2025 | 11:31 AM
popshot's Avatar
Default Fuel pump issue
When is the fuel pump supposed to run? Is it supposed to run on ignition on or does it wait until the engine fires to kick in? Being carbed and having the benefit of gravity I'm a bit surprised it has a pump at all. I'm getting 0v at the pump on ignition on yet this loom started the bike just fine. Put it in the Kitten and the pump actually has to push the fuel against gravity but it's not doing that without power. Any help gratefully received.
Old Sep 13, 2025 | 12:49 PM
Ed Harris's Avatar
The fuel pump receives short pulses of power and a normal multimeter will not register them correctly. If the bike runs, ride it :-)
Old Sep 13, 2025 | 01:12 PM
popshot's Avatar
After some digging around I find that if I bypass the fuel cut off relay I get a steady 12V at the pump, not pulsed. I'm betting on the relay is dud but the bike was just sucking fuel through the system with the aid of gravity. I've ordered a new relay. But if I actually connect the pump on a bypassed relay it blows a fuse so I'm also betting the pump which is an aftermarket thing is shorted out. I'll get a pukka Honda one which strangely have Mitsubishi markings on them!
Old Sep 13, 2025 | 02:42 PM
Ed Harris's Avatar
Good call - I had the wrong model in mind.
Old Oct 27, 2025 | 05:34 PM
forestfarm's Avatar
It needs a pump because at WOT the thirsty girl can drink more than what gravity feed will allow.
khaj1234
Apr 26, 2024 04:01 PM
wooferdog
CBR1000F For Sale / Found
Jun 28, 2015 12:35 PM
Timbostang
Nov 18, 2011 09:37 AM
tomstoy
Jun 15, 2009 08:01 PM
abramj
Apr 8, 2009 08:12 PM
