Engine On stand
Old 09-10-2011, 06:53 PM
bjjrev's Avatar
Default Engine On stand
Has anyone here mounted their engine on a stand? I've seen people on other sites that have made brackets and used a regular engine stand. What points on the 87 cbr1000f would be ok to hold the engine up by?
Old 09-10-2011, 08:58 PM
bjjrev's Avatar
I've seen where people use the harbor freight one and cut some angle iron to mount it using the original mount points... That's what I had in mind...
Old 09-10-2011, 11:57 PM
CBR1988's Avatar
Senior Member & Lord of the Odometer (300,000 Mles) & Counting
Hey:
That is how I do it with a couple of the HF ones, but use square tubing mounted to the flat plate not angle iron. I just slot the plate for use with different motors on the top, and I use L plates at the bottom for the motor mount nearest the swingarm using that long bolt for the stand mounts as well. I also bolt a custom plate for some motors to the HF plate. Manys ways to do this.
Dub
Old 09-12-2011, 09:07 AM
TimBucTwo's Avatar
I don't see the need for a stand personally. Every bike engine that I had out, I've had no problem flipping it around once it was up an the work bench. Dry (no oil or coolant) they get lighter, a little.
Unless you plan on spending many hours working on an engine that warrants the time and effort on making a stand, I don't know if it is worth the pursuit.
I also don't think (for my own personal use) it worth while unless I plan on rebuilding several engines. Engine stand storage space here is minimal.
Old 09-12-2011, 09:24 AM
bjjrev's Avatar
Gotcha... Thanks guys. What I'm gonna do is tighten everything back up and jut wait till I have it mounted in the frame then do a compression/ leak down test. Then if needed I'll tear it down. I might just do a top end while I have it out. Doesn't seem like it's too difficult to remove from the frame if she does need a rebuild...
Old 09-12-2011, 09:43 AM
TimBucTwo's Avatar
How does she shift? If you need trany work I would say pull it. All other work should be able to be done in frame.
Old 09-12-2011, 10:11 AM
bjjrev's Avatar
I haven't run through the gears yet... Bought her in a box for $250
Old 09-13-2011, 07:47 AM
TimBucTwo's Avatar
Let me re-phrase what I posted. If you have everything apart, you will need to install the cylinders and maybe the head out of the frame. There is no room to slide the jugs down over the studs in frame.
If you were originally asking if you can put the engine on a stand and run it to see it it's OK before installing it in the frame, the answer is no (yes but a lot of work). You need to have the battery, CDI and R/R hooked up to run it. Best done in frame. It is also best to assemble the entire engine out of frame.
Head and jugs on trany in frame .....most every thing else can be done in frame.
Sorry if there is any confusion.
Old 09-13-2011, 08:25 AM
bjjrev's Avatar
No worries bro... I was just saying that it is complete and out of frame currently. Thanks for the advice!!!
NEPAF4i
03-18-2014 05:21 PM
bluej511
01-11-2008 11:03 PM
dirtysanchez
08-12-2006 05:40 PM
zer0gh0st
02-19-2006 12:41 PM
Quick Reply: Engine On stand
