electrical issues
Old Jun 14, 2010 | 02:50 PM
jam0837's Avatar
Default electrical issues
So my dad’s bike seems to be killing the battery. I’ve tested everything dealing with the charging system and It all tests to spec.
I also unhooked all the electrical connections and sprayed contact cleaner inside just to make sure they're all clean. When I unhooked the connector from the switch assembly that connects directly to the battery, part number 35850-MR5-007, the connector was fried. attached are some pictures on the connector. Is there a way o could test the switch assembly?
I reconnected everything and started the bike up just fine. I then unconnected the switch assembly again and reconnected it. Now the bike doesn't want to turn anything on. I tested wires for electricity to the ignition switch and it does have power but nothing is working. Idk what is wrong with this thing.
Another problem I was having before I started unhooking things was the headlights didn’t turn on. The bulbs and fuses are fine but they still don’t turn on. I think there is something terribly wrong with the wire harness but I can’t figure out what. This is just one problem on a list of things wrong with the bike.(including carburetor need cleaning, bike running on three cylinders, fork oil leak)
Any suggestions would help greatly.
Attached Thumbnails electrical issues-0611001240.jpg   electrical issues-0611001240a.jpg   electrical issues-0611001241.jpg
Old Jun 16, 2010 | 08:08 PM
Sprock's Avatar
You might want to check out the ignition switch sounds like the culprit might be plain bad !
jordan36
Apr 1, 2014 05:00 PM
JankCibberf2
F2 Tech
Mar 31, 2012 06:19 PM
GarrettSR5
F2 Tech
Mar 15, 2012 11:26 PM
danl23880
Jul 6, 2010 08:00 PM
camaropower
May 31, 2009 01:55 PM
