Downpipe swapout
Old 04-11-2009, 05:43 PM
Harry_T_Hamster's Avatar
Default Downpipe swapout
Is it possible to swap out the downpipes without removing the radiator / draining the coolant ?
Cheers
Old 04-11-2009, 06:43 PM
pacojoseph's Avatar
Not from my experience.
Old 04-12-2009, 08:40 AM
Imo000's Avatar
You might be able to get the two bolt for each of the side pipes but that that'sit, after that the rad would need to be moved. It's really not that big of a deal to remove the rad.
Old 04-13-2009, 03:38 PM
toomany's Avatar
You'll have to drain is, but not remove it. When I put the V&H system on my bike, I just swung it out of the way. There is more room when you remove it though.
Old 04-13-2009, 04:19 PM
Yep - removed it - and then managed to snap two of my studs grrrr - so ordering an extractor and a couple of new studs.
Shall I replace all 8 studs whilst I am doing it ?
Old 04-13-2009, 05:36 PM
Thanks for the tips guys - I will only replace the snapped ones.
The downpipes I am putting on are 304 steel so I hopefully will only be doing this once :-) and its cheaper only doing the two lol.
Good tip with the hammer - will give that a go.
Quick Reply: Downpipe swapout
