Crank won't give a full revolution........
Old Mar 10, 2014 | 10:32 AM
Shadow's Avatar
If you moved the crankshaft gently around and felt the obstruction, you'll probably be OK but If you swung the motor forward and back with vigour, then you'd be better off checking the valve s before you continue.....
Old Mar 10, 2014 | 11:29 AM
DRam's Avatar
Very Honorable Most Senior Member :)
Originally Posted by hmm
Thanks DRam.
I've re-fitted the cams and was able to fit the CCT and set the timing.
But...
Let's assume I have already bent a valve or two (or three or four...); how will I know when I try to start her up?
If you already have everything assembled run a compression check before buttoning up the top end. Bent valve = little or no compression.
Old Mar 10, 2014 | 04:26 PM
Sprock's Avatar
Pray t'aint so ......seriously
Old Mar 10, 2014 | 05:46 PM
DRam's Avatar
Amen
Jordon Bent
Jan 22, 2014 05:48 AM
Hueristic
The Hurricane Saloon
Sep 27, 2012 07:56 PM
Jmclmorrow
Aug 26, 2009 04:23 AM
fireplug
Dec 8, 2006 12:10 AM
kylesbored
Sep 10, 2006 07:36 PM
