Confused and NEED Help
Old Jun 26, 2011 | 12:50 PM
g_bay's Avatar
ok so the first pic is the cam cap the 2nd is the cam chain guide with the broke piece still on it and the 3rd is where the piece broke off with the guide
Attached Thumbnails Confused and NEED Help-3.jpg   Confused and NEED Help-4.jpg   Confused and NEED Help-5.jpg
Old Jun 26, 2011 | 11:34 PM
TimBucTwo's Avatar
The cam cap may be a problem as they are close tolerance items. The caps are line bored to fit the cam. Welding them can be a problem. Finding one to match your engine is like winning the lottery. The chain guide can be bent back and the lug maybe welded back. The cap is tricky.
Old Jun 27, 2011 | 01:17 AM
jarvid's Avatar
Welcome Crew
The cap end is broken the same way as mine was, the welder made up a bracket to hold the pices in place to stop warping while he welded it up, 'a piece of cake to do',were his words, that cost all of AU$88...
Old Jun 27, 2011 | 06:38 AM
Sprock's Avatar
I'd say jarvid is on the money with this one , thing is finding a good fabricator/machine
/welding shop to do it for you
Cut the remainder off the cover use a longer slightly oversized bolt with a sleeve
to grip the remainder at the bottom with some JB Weld ....should hold it down on
that side ....imo
Old Jun 27, 2011 | 08:43 AM
g_bay's Avatar
yeah the thing is finding someone who can do the work for me im in Tennessee. So I doubt that will happen.A junkyard told me 150 for a head that water has gotten in or 200 for a dry one. Then i also gotta get head studs so what another 100 there and alot more work. Hopefully i can find someone to fix the cap. It deff would prolly be alot cheaper and easier.
ricwhy33
Oct 4, 2009 11:33 PM
slamd_f2
Aug 7, 2009 11:50 AM
Speedin4Fun
May 14, 2009 09:55 AM
lilbear777
Jan 15, 2008 09:54 AM
Brando159
Aug 23, 2006 03:41 PM
