Chinese Discs
Old 05-01-2011, 09:26 AM
Originally Posted by kiwi TK
Can you make two while you're at it please Robbie. Mine has only one function, always on, no off, no reserve. I suspect it's the same bit of rubber that's failed on mine, have had a trawl thru the K&L website but they don't seem to have diddly squat for the 87.
Cheers
TK
Ok, stupid question. If the arrow on the petcock is pointing up, is that reserve? I rather not find out the hard way.
Old 05-01-2011, 10:44 AM
DragonCBR's Avatar
Originally Posted by Sprock
In this brake thread by DragonCBR
robbiegraham has the Chinese discs/rotors fitted
Use the Force Henry (in this case the search button lol)
Nope did not have to change them after all, after i changed the brake lever id did about 500km and the warping on one of the disk dissapeared, so i it semmes i saved my brand new set of oem front disks!
Old 05-01-2011, 08:03 PM
robbiebgraham's Avatar
Up is on, down is reserve and center is off.
Old 05-01-2011, 10:42 PM
Sprock's Avatar
I was wondering about that robbie ------- being down under and all ..lol
Old 05-02-2011, 03:37 PM
kiwi TK's Avatar
Crazy CBR Salvage Guy. RIP
Yeah I know all that, the problem I have is that no matter where the arrow is pointing the result is always the same, fuel runs until there is none left in the tank. So if I want to do any work on the fuel system I have to drain the tank first ( I can do this with the arrow in the off position if I feel so inclined). Leads me to the conclusion that the rubber gasket with the holes in it inside the petcock must be leaking?
Old 05-02-2011, 03:45 PM
HenryM's Avatar
Just slightly! TIme for a repair kit.
Petrol Tap Repair Kit Honda CBR1000 F 1990-1995 743538 | eBay UK
Should do the trick!
Or perhaps you just need to tighten the centre screw on the dial up a bit.
Old 05-02-2011, 07:10 PM
What year is your bike?
Old 05-02-2011, 07:13 PM
Nothing like that in the 87!!!!
Old 05-02-2011, 07:40 PM
kiwi TK's Avatar
Mines an 87 Robbie, I suspect what I need is the rubber seal that has 3 or 4? holes in it that directs the fuel intake from the main or the resrve inlets
Old 05-02-2011, 08:00 PM
Does yours leak around the outer seal TK?
Quick Reply: Chinese Discs
