cbr 1000f bogs down at low rpm
RE: cbr 1000f bogs down at low rpm
I've got a '93 with the same V&H SS2R system, 4 into 2 into 1. I also have a Dynojet kit installed. I have no problems as you describe. The hesitation and surging are signs of a lean mixture. Go throgh your carbs as descibed above and make sure the pilot mixture screws are open enough. The screws on the bottom front of the carb control volume only, not mixture.
ORIGINAL: stinky93071
Ok I did some testing on the way to work today.. 3k in 6th gear is 45 miles per hr. and the engine is at total idle (me giving little to no gas)...
Thanks to everyone for your responses. Looks like I need to get a service manual and start checking things out.
The cbr owners manual recommends shifting from 5th to 6th at 37 mph,
but just to set the record straight, I'm not doing a lot of riding in 6th gear below 3k it's just that the low
rpm stumble is more pronounced there than in any other gear.
