Carb help please.
Old Aug 12, 2025 | 01:14 PM
popshot's Avatar
Default Carb help please.
I'm plumbing my engine into a Reliant Kitten. It's a '91 CBR1000F engine and I'm struggling to identify at least one of the connections to the carbs. Can anyone ID me this small hose going to the side of the carbs please? Is it a vaccuum hose as part of a fuel cut off system. This hose is not there on the earlier carb set I have. Thanks.
Old Aug 12, 2025 | 01:25 PM
Not sure if this will help you or not, but here is diagram of what your assembly should look like. Link
Old Aug 12, 2025 | 01:34 PM
popshot's Avatar
Thanks but I can't see that hose on there.
Old Aug 12, 2025 | 01:41 PM
I thought it might be in the exploded subset drawing in the upper left. I do not see the rigid 90 degree tube though, not for the model described anyway.
Old Aug 12, 2025 | 08:45 PM
dmoh's Avatar
I think it's the vacuum hose (#7)
running from the engine side of the carb to the fuel petcock. If you're running fuel directly to the carbs on your setup, just block this pipe, otherwise you'll have a lean carb!
Cheers
Old Aug 13, 2025 | 04:26 AM
popshot's Avatar
Thanks for that.
gearmike
Nov 17, 2023 10:06 AM
re33
Feb 10, 2013 03:50 PM
Lucky 13
Jun 16, 2012 08:22 AM
Hootie233
Jan 24, 2011 08:12 PM
chrisf
Aug 4, 2006 11:15 AM
