Carb boots cracked
Old Oct 16, 2011 | 03:17 PM
obsurfer's Avatar
Default Carb boots cracked
Removed carbs and air box to do a clean and re-jet and found that each carb boot on the air box is cracked and it looks like it has been "glued" before. Any suggestions of how to fix.
Old Oct 16, 2011 | 04:26 PM
TimBucTwo's Avatar
When you say glued, do you mean black stuff? If so, I think that's normal. Hard to believe but others have that black goo on the air box side, I do.
Old Oct 16, 2011 | 05:00 PM
obsurfer's Avatar
Ya you are right, it's the black stuff. Where can I get more to fill in the cracks?
Old Oct 16, 2011 | 11:20 PM
Shadow's Avatar
It's black silicon in a tube.
Local hardware store should have it.
Use dish washing liquid on your fingers to smooth it
Old Oct 17, 2011 | 09:06 PM
obsurfer's Avatar
Shadow, thanks for the info. I am assuming that this black silicon can handle the heat that gets in and around the air box. The reason it cracked is just old age??
Old Oct 17, 2011 | 09:25 PM
Sprock's Avatar
Just an fyi each of those are just $12.63 cents ......@ cheapcycleparts.com
just saying
Old Oct 17, 2011 | 10:16 PM
kilgoretrout's Avatar
Administrator - Retired
Silicone can handle the heat fine. Hell, if you use a black rtv silicone sealant, it's good to like 450F! That's what I would use. It's available at just about any gas station store, wal-mart, etc. Permatex, usually.
And yeah...it's probably just cracking from age. It usually separates from between the box and boots.
Old Oct 18, 2011 | 03:18 AM
Ruaphu's Avatar
Just another method for a slighty different problem with the carbs boots.
One of my other bikes suffered a split carb boot, I found using electrical Self amalgamating (rubber type) tape is an awesome fix.
Heat resistant, fuel resistant, last for ages(years in fact) and most of all, seals any air leaks.
Cheers
Old Oct 18, 2011 | 03:25 AM
Shadow's Avatar
Thanks Dylan - Time delay before I could get to it.........
I also like the idea of using self-amalgamating tape !
My own airbox has black goo around the airbox tubes - probably permatex or something similar - takes the heat fine whatever it is.
Old Oct 18, 2011 | 03:52 PM
Sprock's Avatar
Pretty sure this new handyman in a can might work too LOL
All over the TV here in the US atm
