Can anyone help with my ignition switch
Old May 1, 2009 | 06:13 PM
nutter's Avatar
Default Can anyone help with my ignition switch
i have just got a new ignition switch but i cant get the old one out i have taken a pic of it from under it but it is not held on by nuts any help would be much appreciated
the new switch has 6 wires the old one only has 3 will it work?
Attached Thumbnails Can anyone help with my ignition switch-p1030031.jpg   Can anyone help with my ignition switch-p1030043.jpg
Old May 1, 2009 | 09:10 PM
pacojoseph's Avatar
That first pic doesn't look familiar, but normally the switch is held on with a Torx bolt, which looks like a hex bolt except that it has a star shaped pattern, and you need a torx wrench to get it out.
Old May 2, 2009 | 01:11 AM
nutter's Avatar
what holds the switch in is the round things at each side you can only see the one on the left hand side its the big rusty bit as for the 6 wire its the only one i could find will have to send it back and try to find a 3 wire
Old May 2, 2009 | 01:25 AM
Shadow's Avatar
Best would be to buy the right switch.
You may be able to make that one work, but if not then you're stuck with it and will still have to buy another one..........
Old May 2, 2009 | 01:26 AM
nutter's Avatar
i wish it was Torx bolt that holds it on but its that big round none bolt looking thing to the left hand side it has nothing on it to to get a grip if you look at the 2nd pic the holes at each side is what you use to fix it with
