Brake bleeding issues, Linked brake model.
#21
Black
#22
Funnily enough I've been thinking along those lines with a comment Kilgoretrout made about shaking everything about and re-bleeding, as I have a reasonable lever & pedal I've been considering going out for a short ride over plenty potholes and council neglected roads, and re-bleeding the system upon my return...........
Black
Black
Take it easy though , you don't want to have to do anything like an emergency stop
#23
AT LAST.
I have finally overcome my brake bleeding problems, and have successfully bled the whole system and achieved a perfect pedal & lever, without a hint of spongyness.
I used the Bike to commute to work Thursday, (around a 12 mile round trip) over plenty of potholes and poor quality roads, to see if this would result in the dislodgement of any trapped air bubbles within the system, then yesterday repeated the whole bleeding sequence from start to finish, I took the advice of a number of forum members, and wrapped a small quantity of PTFE thread tape round each of the 6 bleed nipples, to insure against air entering the system during the bleeding process, I then employed a small inline brake bleeding valve to assist in the operation, and was able to finally purge the DCBS of any remaining air.
I consider that a combination of all of the above elements is what proved to finally result in a success, but I am tipping that it may have been the use of the PTFE thread tape round the nipples that was of greater significance........
my sincerest thanks to you all.
Black
Black
