Bar End Weights
Old Feb 5, 2010 | 01:12 AM
Aussie Johnno's Avatar
Ride of the Year ... Just Ask The Boys
Default Bar End Weights
Inmates,
Does anybody know how to remove the entire bar weight form the handlebar.
I need to replace mine, but i can not work out how to remove part that sits's inside the handlebar
Thanks
Aussie Johnno
Old Feb 5, 2010 | 01:18 AM
cbrsixpack's Avatar
November 2009 ROTM
Originally Posted by Aussie Johnno
Inmates,
Thanks
Aussie Johnno
Previously i did this 20 years ago on the CBR600F i dropped at speed....
Squirt a little wd40 or similar inside as far as possible.
Use a cap screw [same thread as your weight] but longer with a few washers floating,use it as a slide hammer to pull the weight out.......
Old Feb 5, 2010 | 01:35 AM
I am heading to the garage now to give it a go, and get another beer, i wonder which will be first?
Aussie Johnno
Old Feb 5, 2010 | 06:01 AM
Shadow's Avatar
You'll have to remove both grips Johno, and you'll see retaining clips inside the throttle and clutch units which need to be depressed to remove the bar end units inside.
It's a bit of a pig but do-able
Old Feb 5, 2010 | 11:18 AM
dietDrThunder's Avatar
I hope you have something pretty heavy to replace them with...these bikes are a little buzzy w/o.
Old Feb 5, 2010 | 11:00 PM
Got it out, took to it with an electric drill, and drilled it out.
Thanks for the input guys, yes i did replace with heavy weights although not as heavy as original but close
Aussie Johnno
hmm
May 5, 2015 09:42 PM
pmcg
Jun 28, 2014 01:13 PM
hmm
Apr 29, 2014 05:27 PM
Terry Fox
Feb 10, 2012 09:46 PM
pacemaker
Apr 21, 2008 02:55 PM
