Back End Walking
Old Mar 19, 2006 | 08:01 PM
MarkR's Avatar
Default Back End Walking
I notice that my back wheel is walking a little
Even though I’ve aligned the markers for the back wheel adjustments, should I use the distances from the swing arm to tire or wheel instead?
My back wheel looks a little bit buckled, how much buckle can I have before I should think about getting it fixed?
Old Mar 19, 2006 | 08:43 PM
slowpoke's Avatar
Default RE: Back End Walking
Try taping a pencil or other soft material on the swingarm so the pencil is even with the rim of the wheel. Spin the wheel and see how much the wheel is out-of-round. As for alignment, I measure from the center of the swingarm pivot to the center of the rear axle with a large caliper I made. I make sure both sides are exactly even.
Old Mar 20, 2006 | 12:30 PM
simochell's Avatar
If your back wheel is even slightly buckled,I wouldn`t risk riding on it!
Is it worth the risk?
Old Mar 21, 2006 | 01:15 AM
olracer's Avatar
take a metal coat hanger, straighten it out...as straight as possible...bend one end about 3/8 inch then take small wire tye...go from swing arm pivot center to axle center mark that with wire tye-compare to opposite side...don't trust swing arm marks...this is cheap true way to check alignment.
Old Mar 26, 2006 | 12:56 AM
MarkR's Avatar
I measure the buckle today, it’s not really buckled, just looks that way cause of the edge of the rim where they fitted the tires.
I measure 0.5 – 1 mm of buckleness, so I happy with that.
I also measure from the tires edge and that was good (about 1mm)
I readjusted the back wheel, the markers where out by the smallest bit.
Haven’t work out the way mention in previous posts yet.
I rode the bike and it is better but still walks a little, may it’s my tire as well as it a 180 and has more wear in the centre than the sides, I going to try some different tire pressures by one or two psi either way to see if there is any improvement.
Old Mar 26, 2006 | 02:33 AM
slowpoke's Avatar
ORIGINAL: MarkR
...I rode the bike and it is better but still walks a little, may it’s my tire as well as it a 180 and has more wear in the centre than the sides...
When it transisitions from the flat center to the rounded sides, the bike walks. Time for a new tire. A 170 might even work better.
montana.matt
The Hurricane Saloon
Oct 19, 2012 06:29 PM
jasonb
Mar 6, 2011 12:59 AM
SeanPMN
Jan 12, 2010 07:11 PM
Ratt
Jul 28, 2009 12:37 AM
