anyone know what the 3 way joint connector for the radiator tubes is called?
Old Mar 10, 2010 | 08:59 PM
iceman423's Avatar
Default anyone know what the 3 way joint connector for the radiator tubes is called?
Bike = 90' Hurricane CBR 1000
Problem = dry rotted 3 way coolant hose connector peice (coolant was leaking then I took it apart and it litteraly just fell apart!)
Details: Does anyone know the proper name OR where I can find the 3-way coolant hose connector which is located underneath the right handle bar under the coolant cap peice im referring to? I'll post a pic if needed tomorrow if no one knows, but it sucks with my phone.
Old Mar 10, 2010 | 09:18 PM
malbojah's Avatar
Part#19
http://fiche.ronayers.com/Index.cfm/...Group/RADIATOR
Old Mar 10, 2010 | 10:53 PM
Shadow's Avatar
Also at www.mrcycles.com
I don't know it's proper name, but I gave it a few new ones when mine broke !!! :eek"
Old Mar 11, 2010 | 09:40 AM
Bassman's Avatar
Default Mr Motorcycle
Shadow,
I see you're listed as being in South Africa. So I have to wonder where Mr Motorcycle is if you are ordering from them or do you NOT order from them? I had been getting OEM parts from Bike Bandit in California. I need to replace some rocker arms in my GB and I see that MR MC is significantly cheaper. I'll swithch suppliers if they're in the US.
Old Mar 11, 2010 | 09:52 AM
Shadow's Avatar
Mrcycles.com are in the US Bassman.
It's cheaper for me to buy everything for the bike overseas, because the local agents are
1 Useless
2 Overpriced by 100% minimum
3 Everything comes from Japan and takes 3-5 weeks.
I even buy spark plugs from Ireland because it's cheaper than over the counter here
Old Mar 11, 2010 | 10:13 AM
Bassman's Avatar
Thanks for the info Shadow. It's going to save me some money for sure. If you ever get over here to Connecticut I'll have to buy you a pint or two.
Old Mar 11, 2010 | 10:23 AM
Shadow's Avatar
Always a pleasure to help !
And I'll take you up on that pint...................
Old Mar 11, 2010 | 03:57 PM
iceman423's Avatar
thanks !
Old Nov 6, 2022 | 06:20 PM
Jeremymrsn12's Avatar
Default 3 way joint connector
The 3 way connector on left side of bike right beside the stator regulator is called a water joint I ordered mine from partzilla . I know your 3 way is on right side of bike up at top of radiator but maybe called the same . I can’t replace my part without dropping the engine
Pedrotamer
Jun 17, 2024 08:01 AM
justice1327
Jul 24, 2013 08:52 PM
cc rider
Mar 30, 2013 07:59 PM
kinglee86
Dec 28, 2010 07:59 PM
kaypee
Aug 7, 2008 02:40 PM
